Some of the keys are not working including enter key
Keys like space bar,some of alphabet keys
    Sniper:
  • 85 Answers
Please try to specify what alphabet keys that are not working. If it extends up to the number keys, then your keyboard is broken and no alternative repair can be done. You need to replace it.
Posted on Dec 11, 2012
djnick989
  • 1067 Answers
SOURCE: Enter,Backspace, Space Bar on Dell Latitude not functional
time for new kb same thing happend on one i worked on go on ebay 16 20 bucks easy to replace opo up top cover covering the screen hinges that plastic then under that 3 4 screws hold kb down with ribben cable pop it up out its litt rackets the rippon cable then pull up leave up with new one installed then push down
Posted on Jan 26, 2008
  • 10865 Answers
SOURCE: keyboard space bar
turn your keyboard upside down and tap it a few times. if that doesnt solve the problem repeat.
If it still won't work write back for more ideas.
good luck and please rate my answer. thanks.
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: It seems like fn key stuck because everything,
Try holding fn key and hitting scroll lock or num lock to see if that does it. sounds like you have somehow locked your fn key on.
Posted on Dec 14, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 1545 space bar, ''n'' and ''b'' keys suddnly don't work
There isn't any "Known Issues" that I am aware of with that model. Try re-seating the keyboard cable, see if there is any difference:
http://support.dell.com/support/edocs/systems/ins1545/en/SM/keyboard.htm#wp1179891
If no difference, contact Dell if under warranty. If not new keyboards are about $20 on EBay
Posted on Jan 15, 2010
moisrkj
  • 7 Answers
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
On my Toshiba Satellite Laptop I have opened and started the computer but can't get past the sign in window because my enter key and space bar won't respond. I can type letters but can not enter...
> hardware problem or software or keyboard?
Experiment #1: turn the computer off. Connect a USB keyboard. Turn the computer on. Use that keyboard to try the 'TAB' key (to move from field-to-field). If TAB works, then try using the SPACE or ENTER keys.
Experiment #2: turn the computer off. Turn the computer on, and look for the message:
PRESS <blah> to ENTER BIOS SETUP
When you see the message, press the <blah> key. On the BIOS SETUP menus, try the ENTER key to "select" a field, to prove that the ENTER key works fine.
Experiment #3: Turn the computer off. Disconnect the AC power. Remove the battery.
Remove the disk-drive. Take the original CD/DVD disk, and start to install Windows to the disk-drive. As you work through the installation screens, you'll need to press ENTER at least once,
if only to acknowledge that installation cannot proceed, because the disk-drive is not connected.
If the ENTER key works, it works.
Experiment #4: Like #3, but connect a different, empty, disk-drive, and reinstall Windows.
If it completes, then your "original" setup has a SOFTWARE problem.
Jul 14, 2011 | Computers & Internet
How can i enter the bios setup of my toshiba satellite a15 s1292?
Press F12 immediately after startup. If you can't press it fast enough then start the laptop with the space bar pressed - you should get a stuck key error and a list of options which should include entering BIOS (also called setup).
Mar 30, 2011 | Toshiba A15-S1292 Notebook
Space bar is not working, all other keys are working fine.
if the keyboard is too old and if you have used it a lot, then ou have to replace the keyboard. The space bar alone had gone.
Apr 03, 2010 | Logitech Wireless Access Duo Optical...
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
Space bar, left-side enter key and backspace do not respond.
Try buying a can of compressed air and cleaning around those areas if you have spilled liquid on them ,that could be the prob as well
Jul 21, 2009 | Logitech S 510 (967555) (DH967555)...
My spacebar issticking.
Yup! you can do that.. carefully... i repeat, carefully pry-upward the space bar using a hard plastic card (I.D cards are best). Clean the hinge with a brush. Press down till you hear a click to return the key back to its position.
Mar 15, 2009 | Dell Latitude D600 Notebook
Wep key entering
network key is very case sensitive no spaces should be there even if there are spaces or a dash when you see it in the router page but when you are entering it in the laptop it should be continous,and make sure you make a note whether the alphabets are in upper or lower case..since it is case sensitive it need to be entered exactly the way it is setup in the router..
vedhick
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
