Question about Kitchen Ranges
Where can I get a manual for a mcClary electric stove?
  • 242 Answers
There are some here if you still have the model.
http://www.applianceaid.com/partsmanual.html
Phil
Posted on Jan 13, 2009
The clock/timer panel on my McClary stove is suddenly pixelated and cannot be set. The timer pings endlessly. How can I disconnect it or fix it?
Hi David,
I am not familiar with this kind of stove, but most of the clocks work the same.
NB, before doing this, unplug the stove.
There is one wire that feeds the clock/timer (this wire is often red). And there is a 0-wire (this one is often blue)
When disconnecting that (red) phase wire, the clock will not run anymore, but neither does the oven.
On the clock must be 1 more wire and that goes to the oven. May be this wire is brown.
Just make a connection with the (red) phase wire and the (brown) wire that goes to the oven.
Then the oven will work again but the clock is out of order.
I hope this helps, Kind regards, Dik
Sep 08, 2017 | Kitchen Ranges
I have a McClary Charm A2746 wood stove.I wanted to know what year it is?
Kathy, There should be a certification plate on the stove some where, listing make, model, year of manufacture, etc., open doors/drawers etc. to see if tag is riveted on inside panel or frame. Check the attached links they may help determine the age of your stove, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
McClary Charm A2746 wood stove Google Search
Antique stoves for sale
Ernie Woodstoves Durham Ontario Canada Repairs Restoration Sales
Strong on Stoves
mcclary wood stove history Google Search
Jul 15, 2016 | Home
Mcclary stove
One thermostat (sometimes at the back of the stove) is open/blown or the door locking assembly has failed. To open the door you may remove the back of the stove; take the door locking assembly apart to release the long wire that hooks the door close.
On some models you can see the locking the latching mechanism through a **** in the top front and can play with the mechanisms there to release the door.
Then you can begin to figure why the door latched in the first place.
Oct 20, 2013 | Kitchen Ranges
Need a manual for stoves 720 ef double oven
Supply an email address and I will register you on my BT Digital Vault where you can access and take a copy of the entire handbook
Dec 31, 2009 | Stoves 720EF Electric Double Oven
How to reattach door onto stove
pull the tips of the hinges down with a reg. pair of pliers until they stay in position. take the door and there should be a slot on each side where the hinge goes in. position 1 side and start it then teeter the door to start into the other slot. make sure it looks even on both sides then give a good push and the hinge guides should go all the way into the door and you are done...you might have to try a couple times. but, with these instructions you will get it good luck and let me know how you do goodday//
Nov 13, 2009 | Kitchen Ranges
McClary washing machine won't spin. A technician
washing machine fills up to much with water on med fill and not enough on min fill
Nov 03, 2009 | Washing Machines
Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
Mar 02, 2008 | Ovens
Kitchen Ranges Logo
410 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
