Question about Zanussi Dryers
Zanussi TD4113W tuble drier - drum front felt gasket damaged
Hello Fixyas I have a Zanussi TD4113W tumble drier The felt gasket between the drum and the door hole is showing and part is ripped. A piece 3" long has ripped off and the gasket slides out of recess into main drum. We have had also lots of black marks on corners of laundry that gets caught in the "gap" at around 11 o clock position when viewed from front. I think it is this part: http://www.espares.co.uk/part/tumble-dryers/gaskets/zanussi/td4113w/p/1583/332/0/510749/103723/tumble-dryer-front-drum-f.html but not sure. Can anyone help with identifying part. Tell me how easy it is to replace it? Am experience at replacing parts in oven, washing machines etc Drier is out of warranty etc Thanks Terry
jsrock516
  • 5911 Answers
SOURCE: black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Posted on Jul 06, 2007
sonicboomele
  • 1557 Answers
SOURCE: my zannussi TD4113W tumble drier has stopped
it sounds like the belt has broken or the motor has burned out try starting there
good luck
Posted on May 15, 2010
  • 2468 Answers
SOURCE: How easy is it to
you first remove the top cover,then the front cover then the drum belt and drum come out the front,and the bearing can then be accessed
Posted on Oct 14, 2010
SOURCE: fit felt drum seal to zanussi td4212 w tumble dryer
I take it that the belt is ok and the drum is turning.The heater comes with thermostats fitted as a complete part.There is an overload safety thermostat which is situated inside the drum and above the door,it is held in place with a self tapping screw then prise open the plastic cover and then the thermostat will pull out,if replacing remember to refit the small gasket.Have you checked the filters and exhaust hose for any blockages as this will affect the heating.
Hope this helps
Posted on Jan 22, 2011
  • 389 Answers
SOURCE: zanussi tumble dryer tds 280w front gasket snapped
it is the drum gasket that goes round the inner drum that forms a seal and acts as a buffer for the drum to ride on if not replaiced the dryer will get noisy and wear the drum out they are stuck on with a glue
Posted on Nov 06, 2011
How do I replace the front felt bearing on a zanussi tumble dryer?
The top and back panels have to come off. The belt taken off and the bowl removed from the machine. Lie the machine on its front. You can then see where the felts go. Some of them are held in with steel spring clips, early models are glued in onto the lip that supports the drum.
Jan 03, 2015 | Zanussi TD4112W Electric Dryer
Zanussi tumble dryer tds 280w front gasket snapped
Nov 06, 2011 | Dryers
How easy is it to replace the rear bearing on a Zanussi TC7102W Tumble Drier, do I take the whole drier apart to do it? Thank you
Oct 14, 2010 | Dryers
My zannussi TD4113W tumble drier has stopped tumbling .It still is heating up ok .Can I fix it ?
good luck
May 15, 2010 | Zanussi TC7114W Electric Dryer
Fit felt drum seal to zanussi td4212 w tumble dryer
Hope this helps
Feb 12, 2010 | Dryers
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Tumble dryer fault
usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through
replace both rollers or both felts if one is worn
Jul 01, 2008 | Zanussi TC7114W Electric Dryer
Tumble Dryer
how do i fit felt gasket on front of dryer?
Oct 10, 2006 | Zanussi TD4100W Electric Dryer
Dryers Logo
77 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
