Question about Ovens
I have an electic self cleaning oven: BALAY with no nstructions in english can I download them?
I AM UNABLE TO MAKE THE OVEN SELF CLEAN AS I HAVE NO DATA ON THIS
Trifect7
  • 57 Answers
SOURCE: Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
Posted on Mar 02, 2008
reg501
  • 413 Answers
SOURCE: cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
SOURCE: Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Posted on Jun 11, 2009
Frigidare feb30s5g inwall oven after running the self clean cycle the oven and broiler coils will not heat. the fan, lights, front panel all seem to be good elect to all. No fault codes are anything. Just...
The oven gets extremely hot during the self clean cycle, and it is common for it to trip the high limit thermostat located in the rear of the oven. If the problem happens when not in self clean, then you may have a weak high limit, or a bad temperature probe.The switch is located on the upper back left side of the oven. Here is a diagram of the oven. The switch is #119.http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=903528&pkw_=basket&model_id=5160477&NewWindow=1
Here is a link to the thermal switch in case you can't rest the one on your unit.http://www.appliancepartspros.com/Appliance-Parts/frigidaire-switch--thermal-item-number-ap2126993.aspx
Try to do the reset and post back your results.
Oct 22, 2011 | Frigidaire FEB30S5GC 30" Single Electric...
Upper oven will not self clean. The door lock does not actuate when self clean is selected. All other functions seem to work OK
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | GE Profile JKP56 Electric Double Oven
Frigidaire electric drop in oven has blinking door locked light on. F9 error message. Tried to self clean, oven never got hot, door locked and can't get open. Been 2 days. Self clean light will not come...
http://b2b.frigidaire.com/support/manuals.asp
this is a free download site from frigedaire if you have your model number you can download your complete manuel i was unable to find the F9 code for an oven
but suspect it has to do with door lock switchs if you can download your manuel from site it may help you can try shutting off breaker for oven and see if it will reset
good luck ron
Dec 11, 2009 | Ovens
Self cleaning oven help
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
Jun 19, 2009 | GE Profile JTP56 Electric Double Oven
Need directions for self cleaning oven
Hi Debi
Unfortunately I was unable to find the manual in my database. But still found the solution you can click on these links and refer to the instructions :
How to self clean Gas Single Oven
Directions for cleaning Fridgidaire
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks Rylee
Apr 08, 2009 | Frigidare FGB24S5DC Gas Single Oven
Cant unlock self clean oven door
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self Clean does not work
heatman101
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
170 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
