Question about Transmission & Drivetrain for Ford Transit Connect
Ford aod transmission won't shift to 3rd gear
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ford Master
  • 1,449 Answers
Check your transmission fluid may need topped up if low or if very dirty then needing a flush.
Posted on Dec 02, 2013
2 Suggested Answers
suarezelec20
  • 259 Answers
SOURCE: just got my aod transmission rebuilt on a 1993 f150 an now win u put it in drive an let off the brake it shuts the truck off
If rebuilt by a business, have them redo it as they may have a certain amount of day warranty on their work. If you mess with it, they will say then that you voided that warranty. If done by you, check your idle and see if it is set right.
Posted on Sep 24, 2012
My 1999 ford ranger shifts hard from 2nd to 3rd gear what is the problem I recently changed fluid and filter but shifts hard !
Auto Trans not shifting correctly from 2nd to 3rd - Ford Explorer ...
www.explorerforum.com > ... > Under the Hood
May 8, 2004 - 19 posts - ‎9 authors
Auto Trans not shifting correctly from 2nd to 3rd Under the Hood. ... Become an EliteExplorer. Lithuania. 1999 5.0. Join Date: Jun 2003. Posts: 107 ... When this happens, the transmission will skip to the next gear like you said.
Transmission Harsh shifting - YouTube
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
... Doctor, explores the causes of harsh shifting in automatic transmissions. ... Early diagnosis is important to ...
Hard Tranny Shift between 2nd & 3rd - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Feb 24, 2012 - Hard Tranny Shift between 2nd & 3rd Super Duty & Heavy Duty. ... I just got a new to me 99 f250 5.4 V8 SD XLT 4x4 Auto Trans longbox 118k miles. ... it out and said it was solid except for a hard shift between 2nd and 3rd gears. ..... Hard shift between 2nd and 3rd, Brenda Lamka, Explorer, Sport Trac, ... hard shift 2nd to third gear only 4r100
Dec 26, 2012
hard shift into 3rd
Nov 4, 2009
4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK ...
Mar 15, 2007
00 Expedition trans shifts late and hard
Jan 01, 2016 | Ford Cars & Trucks
Why won't a 2005 Taurus with a fax transmission shift into 3rd gear?
run the fault codes and check for a servo/solenoid fault or a faulty TCM module.
Jul 16, 2014 | 2005 Ford Taurus 3.0
Selecting 3rd gear
Do you mean you can\'t find 3rd gear or it won\'t shift into 3rd gear? If you can\'t find 3rd gear, shift all the way down to neutral, then shift up 2 clicks. On my Suzuki Boulevard S-50 (VS-800) the shift order is 1st gear down, then up for neutral, 2nd, 3rd, 4th, and 5th. Your crotch rocket probably also has a 6th. If the problem is that it won\'t shift into 3rd, then you had best take it to the shop as it is not readily repairable without specialized tools and knowledge.
Oct 02, 2013 | 2003 Suzuki GSX-R 600
It won't shift into 3rd gear until i get to 50 mph everything else works great
transmission clutches bad for third gear operation. needs trans overhaul..
Jan 18, 2013 | 1996 Dodge Caravan
My 1990 ford f150 aod transmission won't shift from 2nd to 3rd
Assuming it is full of fluid, normally I would say its a pressure problem inside the trans. But is it possible the shift linkage is not back together correctly ??
Jul 28, 2012 | 1990 Ford F150
Ford AOD Transmission
pull it out and put the old one back in
If you want to replace it , get a reconditioned unit from an accredited professional auto repair shop and then you get a warranty as well
May 21, 2017 | Cars & Trucks
My ford F150 won't shift from 2nd to 3rd. Does anyone know what could be the issue?
Usually the transmission needs to be rebuilt in that situation. It's a very common problem if that's the famous automatic overdrive transmsission. AOD I have had three trucks that have done that. It usually starts by shuttering when it shifts and than finally goes out. Sometimes the Lucas transmission treatment gives you a little more time, but it sounds too late for yours. From what I understand (mechanic told me) that when the overdrive goes out, it takes third gear with it. If you drive in hilly areas, that overdrive is shifting in and out all the time as you go up and down hills and wears it out. My Dad had that hapen on his F150 and he replaced his transmission with a junk yard transmission that turned out to have the same problem. I had that transmission replaced with a Jasper rebuilt and it worked great. I think it was $1300 for the rebuilt trans with the old one core trade in. I think when 3rd gear goes out, you can only go about 45mph without over reving the engine. I saw that same problem with a Ford Crown vic with that same transmission and 302 engine that my neighbor had.
Did your third gear just go out all of a sudden or were you getting like a shuttering or kind of a grinding sound when it shifted?
Aug 05, 2011 | 1998 Ford F150 Regular Cab
Just had both o2 sensors replaced and now the truck won't shift from 2nd to 3rd gear. Evidently it had been slipping a bit before but now it won't shift into 3rd at all. The tranny is an E4OD......
O2 Sensors --- not related to shifting
New transmissions --- are only new once
When installed on the assy line
Has to be rebuilt if necessary
PO 147 ---O2 Sensor Heater (Bank 1 Sensor 3) don't have one of those
PO714 -- Trans Temp Sensor -heat for the slipping
PO 471 --- Exhaust Pressure Sensor -don't have that either
Need a new guy
Not very professional were they
Jun 13, 2011 | 1997 Ford Expedition
1985 150 ford aod transmission will not shift 3rd. and overdrive does not shift out 1st. or 2nd. till 3000rpms.
check your fluid level if its good find the rubber hose from transmission to carb or intake. make sure there is no kinks or cuts. if the rubber hose from the modulater valve on the transmission is not hooked up its not going to shift right hopefully its not your pump or stuck valves
Mar 09, 2010 | 1985 Ford F150
Transmission & Drivetrain for Ford Transit Connect Logo
242 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
