Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Canon ir3300 error code E00602-003 - Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
4 Suggested Answers
SOURCE: each time l switch on my machine canon ir3300 l have e000007-0000
Try this press additional functions,2 and 8 keys at the same time,additional functions,copier, function,clear,err.power off and on. If that does not work you will need a tech to fix your fixing unit.
Posted on Oct 14, 2009
SmartFix
  • 89 Answers
SOURCE: what is error code e000014-0000 on canon IR3300
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Rate my response!! Thanks, SF
Posted on Jan 28, 2010
canontech
  • 1219 Answers
SOURCE: error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller
Posted on Apr 30, 2010
Error code E000350-0001 in ir3300
Its the serial number board. Someone swapped the main controller out and didn't change the small serial number pcb with it. That board HAS to be returned to the machine or it will not function. Only way to get a new board is through Canon engineering.
Feb 11, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do i solv error 100 code in canon ir3300
Hi Raj
please follow link it will give you all the error codes and also will tell you what your one is..hope this helps
Dec 23, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do I fix error code E000014-000 for my Canon ir3300 copier
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Sep 09, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Code Error in cannon ir3300
Hi Abhishek,
Go To Below official Canon Printer Page For Your problem Error Codes Canon iR3300 Still having Problem Then follow Us For Canon Printer Support
Mar 12, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Hard disc error
the error refers to PDL board mounting error- suggest if the machine has been moved or if any parts have been removed or replaced you check ALL pwb board connections this could take some time to complete try to start where you have been working in the machine first.
Jan 16, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
I need error codes for canon ir 3300
Hello, Here is a link to the full list of all the Canon iR3300 error codes with full details.
http://www.printcopy.info/index.php?l=en&mod=free&chap=erc&brand=Canon&model=iR3300
May 20, 2011 | Computers & Internet
Error code 000000-0000 in connon ir3300
The error code E000000-000 means that you have a problem with the fuser unit. Did you have a power outage recently???? That may have been the cause of the code. Or you may need a new fuser unit... Did you try to rest the error code in service mode?????
Mar 29, 2011 | Canon Office Equipment & Supplies
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
Jul 30, 2008 | Office Equipment & Supplies
Computers & Internet Logo
49 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
