Question about Nokia C503 Cell Phone
Where to enter master code sir for nokia c5-03
    New Friend:
Am un nokia 1800 vreau si eu un cod sa mearga pe orange
Posted on Jan 12, 2013
  • 113 Answers
SOURCE: Nokia 3500 Unlock Code Fido Carrier, Canada
IMEI: 357688014944913
Security Mastercode: 1200507757
Good Luck!!!
neo
Posted on Mar 01, 2009
abhi2664
  • 3 Answers
SOURCE: master code for all nokia 3110
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#06# : Checking the IMEI (International Mobile Equipment Identity)
*#7780# Restores Factory Settings (Memory, language, counters are not included).
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#746025625# [*#sim0clock#]
Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#92702689# [*#war0anty#]
Press the following warranty code :
6232 (OK) : Displays the Month and Year of Manufacture (0997)
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove SIM card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key.
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Posted on Jun 10, 2008
Fixe_You
  • 1800 Answers
SOURCE: nokia 5310 keep saying code error when i enter master code?
try *#7370# or *#7780#
default scurity code is 12345
Posted on Jun 22, 2009
SOURCE: Unlock nokia 3110c phone, master code needed.
open the web site wap73.com in yiur mobile and click enter>unlockphone enter your imei no. and you get master code for your mobile
Posted on Jan 29, 2010
SOURCE: Nokia 3500 Classic Unlock Code Fido Carrier, Canada.
I don't know
Posted on Mar 22, 2011
I dont know my lock code sir please tell me sir imei no 353777005895079
1 - Switch on your Nokia 6600 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6600.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6600 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6600 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6600
Nov 15, 2011 | Nokia 6600
Nokia 1650
sir i am nokia 1650 mobile lost my paasward so pls give master reset unlock code
May 29, 2010 | Nokia 1650 Cell Phone
Sir plzzzzzzzzz unlock phone imei
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For your imei no. the master security code is :
6357407066
May 17, 2010 | T-Mobile Nokia 2610 Pay-As-You-Go Cell...
I FORGET SECURITY CODE FOR NOKIA 6275 CDMA PHONE
i need ur imei no. for dat or do this go to this site :http://www.unlockme.co.uk/master.php
enter ur imei number here and get the master code .enter that master code to reset ur security code to 12345 again
Feb 20, 2010 | Nokia Cell Phones
Hi in my nokia 1600 forget secutity code my imei no is : 354574/01/012399/6
By following your IMEI, I generated the master code by my master code generator. Just enter the master code. It is 0354126700
Thank you Sir, Have a nice day.
Sep 25, 2009 | Nokia 1600 Cellular Phone
I need nokia country resrtiction code for nokia 6500s. IMEI number is 353077/02/797794/2
Hello, enter 3603243744... that is your master code, use that in place of your security code
Aug 25, 2009 | Nokia 6300 Cellular Phone
PLZ SEND SECURITY CODE NOKIA 1110I
you will get the security code at www.nokia.com.please enter the model name there u will find it
Aug 07, 2009 | Nokia 1110i Cellular Phone
Master code
Find out your IMEI code and go to the site
http://nfader.su/index.php
Enter your code there..They will give you master code ..
Type this code instead of security code..
Oct 22, 2008 | Nokia 6233 Cellular Phone
Nokia C503 Cell Phone Logo
60 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
