I've checked the power and the outlets and I've still got nothing. I've had no problems with this until now. mid-cycle it beeped 6 times and turned off and hasn't turned back on since. please tell me whats wrong with it and how to fix it.
SOURCE: need service manual for HAIER HDT18PA countertop dishwasher
Click the link, then click the picture of the manual on the page, it will begin loading the manual.
HDT18PA Haier Table Top Dishwasher
SOURCE: Haier Dishwasher hdp18pa - Power reset
Are you blowing a fuse or throwing a breaker? Either way there is a chance that no outlet you have chosen to test with yet is on a circuit with sufficient amperage-I had this with a microwave I recently had installed. If you have the manual, check for requirements regarding amperage. You then need to be sure you are using an outlet with amperage comparable to the requirements-this is on your fuse or breaker. If your requirement is, say, 20 amps, a 15-amp or less breaker or fuse is going to fail. I had to go to a 'clean' circuit from my garage with nothing on it to find out I did not have enough amps in my circuit. My solution was a dedicated breaker. Another option is to use my second option (which I did not need), to plug it into a gas generator with sufficient wattage/amperage. This ensures nothing else is on the circuit.
Failing all that, it could be the power supply for the washer, a circuit board issue, etc. Don't mess around if you don't understand electricity, though-it's not worth frying yourself.
Finally, if it worked ok before and this has just begun to happen, I'd tend to think it's an issue with the washer itself. Hope this helps.
SOURCE: haier dishwasher
I useto have same problem. For some reason there was water under machine, then i tilted machine, clean water and problem solved. This is built-in dishwasher that is why water acumulates under machine and "leak cut off switch" turn off machine. You can't reset machine while you have water under, machine telling you there is a problem, but Haier wan't put solution on their site - Haier suport is very bad. Sorry for English and hope this help.
SOURCE: Haier dishwasher wont run and shows a code OP
The code "OP" means the door is open. I would suspect you have a faulty latch. The dishwasher thinks the door is open and will not start the cycle.
SOURCE: Hello, my Haier dishwasher stopped
Have the same problem with mine and have found no solution in the manual or web. four lights flashing and beebs ten times every ten seconds, water coming in and draining out constantly, very frustrating!
