Question about Refrigerators
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
  • agboulton Jan 13, 2009
    Yes Thanks I hope this works
  • 306 Answers
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Posted on Jan 13, 2009
On the temperature scale I am not sure what max and min mean. Is it the maximum lowest temp possible or the minimum temperature possible. Have never been able to work this out.
Min is the least effective, Max the most, min gives best economy for fridges not used much, max is for if you use it a lot and it needs to run longer. As with anything like this, settle for midway point and you can't go far wrong!!!
Aug 20, 2012 | LG Refrigerators
Ice maker not working. refrigerator is freezing everything. seems to run all the time.Help!!!!!! It is an Amana about 10 yrs old.
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
Aug 01, 2010 | Amana ATB1832AR Top Freezer Refrigerator
The top part of the refrig keep freezing?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Apr 14, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
Food freezes in the fridge part even at the highest
If it is freezing, either you need to turn both temp down to 2nd to lowest setting. Cold air does sink, so that is why crisper gets colder. There is a flap and vent for air between the fridge and freezer. The flap can get stuck in one direction, or the acutator that moves it can become faulty. A leaky door seal will also make the opposite compartment colder.
Oct 11, 2009 | Frigidaire GLRS263ZD Side by Side...
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
My engine keeps blowing out the anti freeze through the fill tank overflow. I have a 2004 Super Duty 6.0 turbo.
start you truck. let the temp gage get to where it will start blowing the antifreeze out. than turn your heater on full blast. if the temp goes down and the water doesn't come out than you need to change you thermostate.
Aug 02, 2008 | 2005 Ford F 350 Super Duty
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
Refrigerators Logo
281 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
