Question about Toshiba Satellite Pro A200-EZ2205X Notebook
ISKAA LA-3481P reboots where is the problem - Toshiba Satellite Pro A200-EZ2205X Notebook
  • 21 more comments
  • chris
    chris Dec 13, 2012
    i check all this to tell me and nothing happpens tha same problem, i read for another mainboards to change capacitor nec-tokin but this mainboard haven't this peace near cpu and under from mainboard have 5 capacitors 330mf maybe i change this to fix the problem?
  • Brian Sullivan
    Brian Sullivan Dec 13, 2012
    how long after you restart does it reboot is it running for any certain ammount of time ? you might have a virus or malware have you tried safe mode option
  • chris
    chris Dec 14, 2012
    no no my friend the hd is formatted disk now i reset the bios and put thermal paste everywhere is needed (cpu,gpu, etc) but now not restarts but shutdown the pc.... i suppose that is the capacitor down from cpu (330mf) like nectokin from another type of mainboard, what is your opinion?
  • Brian Sullivan
    Brian Sullivan Dec 14, 2012
    have you done any modifications ? it might be something simple before you delve into capacitors have a close look at ram modules even remove then reseat them also check the laptops external battery and cmos battery it might be hard to check if its the external battery if the computer does not run
  • chris
    chris Dec 14, 2012
    this laptop haven't battery i remove the bios battery and i setup it again.... but nothing.... I am concerned when i remove the ram from one slot and put it another the latpop not start's but when i put it again to the other slot work's fine with the problem i mention..
  • Brian Sullivan
    ram needs to be compatible to able to work in other computers just remove have a look for debri or dirt on ram module and ram socket then reseat the ram
  • Brian Sullivan
    Have you done any modifications to this computer ?
  • chris
    chris Dec 14, 2012
    i 'll try with another ram to test it and the same problem again with slots
  • chris
    chris Dec 14, 2012
    maybe the cpu fault with power managment and i say about capacitor's ... when the pc is power on and works fine about 3 minutes when shutdown i was install program for cpu diagnose an says to me the cpu is burning with 45 celcious temparture...
  • Brian Sullivan
    45 deg celcius should be ok
  • chris
    chris Dec 15, 2012
    yes it's ok i know that but the cpu thinks that is overheated....and i say the issue with capacitors like nectokin.....
  • Brian Sullivan
    Brian Sullivan Dec 15, 2012
    yes it could be a bad capacitor To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of size and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base
  • chris
    chris Dec 15, 2012
    yes but wich capacitor optical all capacitors are ok... maybe capacitors near cpu? 330mf? take a link for mainboard to see my mainboardhttp://www.howtofixit.gr/forum/showthrea... check images
  • Brian Sullivan
    the link took me to a russian site or at least i think its russian i think joe coolvette might be your man he is an expert with these
  • Brian Sullivan
    Brian Sullivan Dec 16, 2012
    How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0ph... Identifying bad capacitorshttp://www.youtube.com/watch?v=ngA4k32jL... Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY...
  • chris
    chris Dec 16, 2012
    hehehehe...... it's a greek site im from greece. this links write it to see the pics from mainboard
  • chris
    chris Dec 16, 2012
    the capasitors from a laptop mainboard told smd it's a small like chips....who is joe coolvette and how i find him to help me
  • chris
    chris Dec 16, 2012
    i find it something else the output from dc power is 19V and 4,7 A but laptop needs 19V and 6,4A i must check this but the previous user told me tha laptop works fine ... i don't understand
  • Brian Sullivan
    http://www.fixya.com/users/joecoolvette
  • chris
    chris Dec 22, 2012
    thanks for help, how i send joecoolvette mail? i don't see nothing to send him private mail
  • Brian Sullivan
    Brian Sullivan Dec 22, 2012
    you might hear from him soon i added your link throught add comment you might have to add comment on some of his answers (interupting) scroll through his answers until you see something associated with capacitors or similiar and add comment with a problem question
  • chris
    chris Dec 22, 2012
    thanx my friend
  • Brian Sullivan
    no problems hope it all works out
  • Toshiba Master
  • 27,725 Answers
Check to see if there are any keys stuck/depressed. If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck. Make sure the laptop is off before attempting this. Observe where the boot process ends and starts over. In most cases, this will give an indication where the problem occurs. If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue. If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software. Test all power and data leads that attach to your hard drive SATA the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty. even something as small as faulty fan lead can cause you problems computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly. Motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in If your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be running your computer over its limits causing memory dumps also under processes see what is ticking over in the background you might have a virus again if you see something you dont need to be and users you will see who is using your computer
You might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility of the ram before making any purchase Might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Hope this helps.
Posted on Dec 11, 2012
On startup error 1962 no operating system found
Pasos para hacer bootear Windows:
-apagar el equipo
-encenderlo y presionar constantemente la tecla F1 para entrar al BIOS.
-dentro del BIOS nos vamos al sub-men? Startup y lo configuramos de la siguiente forma:
***Startup***
*Primary Boot Sequence
*CSM: [Enable]
*Boot Mode: [Auto]
*Boot Priority: [UEFI First]
*Quick Boot: [Enable]
*Boot up Num-lock Status: [On]
add image in the mode perfect.
May 21, 2014 | Lenovo IdeaCentre K450 57315522 Desktop PC...
Rebooter
The problem is in the fusing unit,fuser warm up error.Enter in the service mode:Press utility key Meter count key introduction 00000000 press enter select trouble reset.
Jan 24, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Sche matics for a toshiba satellite A205iskaa la-3481p motherboard so i can reset the bios password or remove it.
Hi schollmd
DISASSEMBLY GUIDE FOR TOSHIBA SATELLITE A205 LAPTOP
On certain laptops, it is possible to delete the BIOS Memory by temporarily disconnecting the CMOS/RTC Battery before reconnecting it and reassembling the laptop.
Sometimes this requires almost total disassembly of the laptop.
So no damage is done during disassembly and the correct component positions and cable connections are restored during reassembly, this is a job best done by an experienced repair technician.
While yellow is a common colour, the CMOS/RTC Battery can also be encased in blue, brown, black or green plastic.
On some models the CMOS/RTC Battery is accessible without disassembly, via the Wireless Card compartment underneath the laptop.
On other models, disconnecting and reconnecting the CMOS/RTC Battery is ineffective in clearing the BIOS Memory Cache because nearby capacitors store the data if the Battery is removed. Two contact points on the motherboard have to be bridged in order to dissipate the charge from the capacitors to reset the BIOS.
The Step-by-Step Disassembly Guide for this model series of laptops can be viewed here:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-4.htm
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 01, 2011 | Computers & Internet
La computadora no tiene sonido, no se si es que esta mala la tarjeta de sonido
ve a device manager. y unistall los sound drivers. luego reboot la pc. y automaticamente despues del reboot se le instalaran los drivers correctos.
2) si eso no funciona busca los drivers correctos de tu sound card de la compañia que los iso e instalalos
3) si ninguna de estos pasos no te funciona pueda ser problema de tu tarjeta de sonido
sige el link a youtube como hacerlo
Dec 02, 2010 | Dell Latitude C610 Notebook
Es un problema tecnico me marca f100 es de una copiadora toshiba e-studio 452 y pues necesito reestableser el servicio de esta maquina espero atiendan este problema y den solucion gracias
Tienes problemas con el disco duro de la copiadora, puedes formatearlo haber si se restablece, para eso tienes que:
1.- prender la copiadora presionando 0+8
2.- poner 690 y presionar start
3.- poner 2 y presionar set.
4.- esperar el mensaje en pantalla de reboot the machine, puede tardar hasta 5 minutos despues de ahi tu disco esta dañado y necesita reemplasarse, junto con el firmware.
5.- apaga la copiadora y vuelvela a prender.
has pruebas funcionales.
Sep 16, 2010 | Toshiba e-Studio 350 Copier
Monitor
Hi ahmed,
Click start>my computer, right click>properties>hardware tab>device manager>monitors>choose your installed monitor and click uninstall>reboot.
anaanymous
Oct 16, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Screen Issues
sounds like your video card is starting to fail mite need to install a new one ,need to do assp or mite loose entire system. la la linda
Jun 01, 2008 | Toshiba Portege S100-S1133 Notebook
GATEWAY LAPTOP
need to know if it is vista or xp then i can make a suggestion! la la linda
Jun 01, 2008 | Gateway Computers & Internet
CPU
test the bios battery, it should read 3vdc. if that fails, remove the bios battery, remove and re-socket the cpu and memory, then hook the bios battery back up. once booted, go into the bios, restore factory or fail-safe defaults, save, and reboot.
let me know if this helps,
trin
broken french translation:
examinez la batterie de bios, elle devrait lire 3vdc.
si cela échoue, enlèvent la batterie de bios, l'enlèvent et re-douille l'unité CPU et la mémoire, puis accrochent le dos de batterie de bios vers le haut une fois initialisé, entrent dans le bios, reconstituent l'usine ou les défauts fiables, économiser, et les rechargent.
faites-moi savoir si ceci aide,
trin
Nov 13, 2007 | Computers & Internet
Toshiba Satellite Pro A200-EZ2205X Notebook Logo
200 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
