Question about Philips CDR775 2-Disc CD Recorder
Thanks everyone. I should clarify that the cds that will not play in the right hand tray (originals) are as pre-recorded by a record company; for example, an ABBA cd which I used to be able to play, I can't now. All my previous recordings onto blank cd-r or cd-rw work fine. Every disc (original or not) play well on other cd players in the house.
  • 1,267 Answers
What does the lower surface look like? Does it have a lot of scratches or is it perfect? Many times the condition of the optical surface of the disc can affect the results you have. The disc is scratched can be polished. Burned disc only have about 70% of the output that a pressed disc has so sometimes you need to burn a new one.
Posted on Dec 11, 2012
  • 112 Answers
SOURCE: optical error
Your laser is failing. There is a test mode sequence you can try to re-calibrate it but to be honest it's the beginning of the end. I can supply replacement laser assemblies depending on where you are in the world or I can email you the service manual so you can try adjusting it yourself. Email me via ebay - fluffcat1
Audio cdrw's are still freely available in the UK.
Posted on Dec 28, 2007
  • 112 Answers
SOURCE: Phillip CDR778
You can try other brands of audio cdr but it sounds like your laser is on it's way out. Some find cdrw's still work after cdr's have stopped being recognised.
Posted on Jan 22, 2008
dunnbiker
  • 8546 Answers
SOURCE: Philips CD recorder CDR870 not recording
Consumer CD recorders require CD-Audio or CD-Music blank CD's to record.
Posted on May 16, 2009
SOURCE: Hello i have a Philips cdr 870. With every blank
You are probably inserting blank computer discs, eg 650 or 700mb rather than blank music CD-R or CD RW`s which this machine is designed to work with. The correct discs are labelled "music audio" or 80 minutes. You can only use these types of discs. Why? When these recorders first came out, it was a way of battling piracey in copying discs. I believe there is a "hack" to enable this player to use blank computer discs.
SMA
Posted on Jan 17, 2010
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
May 09, 2014 | Emerson EWR20V4 DVD Recorder/VCR
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
Which disc can be used to recrord on ?
According to the user manual, the following DVD media you can record with this unit are:
RECORDING: TYPES OF DISCS YOU CAN USE FOR RECORDING
DVD+R 2.4x, 4x, or 8x ONLY; DVD+RW 2.4x and 4x ONLY.
NOTES:
It is NOT possible to record on CD-R or CD-RW discs.
IMPORTANT: It is NOT possible to record content that is copy-protected. This is usually true for most pre-recorded DVD discs and most pre-recorded VHS tapes.
PLAYBACK: TYPES OF DISCS YOU CAN PLAY
DVD discs - DVD movie discs (DVD-ROM); DVD+R; DVD+RW; DVD-RW (must be recorded using video mode or VM); DVD-R (must be recorded using video mode or VM and must be finalized).
CDs (Audio CDs, CD-R, CD-RW) - Audio CDs contain musical or sound content only. mp3 discs are CDs (CD-R or CD-RW)
that contain mp3 files. This product also plays CDs that contain JPEG files and Multisession CDs.
Video CD (VCD) and Super Video CD (S-VCD) discs - Like DVD video discs, VCDs contain picture and sound content. The difference is the amount of information that can be stored on the disc.
VCDs typically have lower picture and sound quality than DVD discs.
Super Video CDs (S-VCDs) can be used to record up to 70 minutes of digital sound and video, with MPEG-2 standard video and MPEG-1 standard audio-but you must use DVD+R or DVD+RW discs to record on your DVD/VCR not S-VCDs.
Additionally, S-VCD disc compatibility is dependent on which MPEG coding software, disc design software, and disc writer software are used; and the discs themselves.
(The above information is extracted from the user manual for this particular model and is a guide only)
I find it very strange that the user manual does not provide any information about DVD-R recording since this is a DVD recorder. I guess you could try those types of discs in it, otherwise it will playback finalised DVD-R discs recorded/burned in another machine.
I assume you have the original manual for this unit. If not, you may be able to download it free from various sites. (retrevo may have it but they may ask you for email address prior to downloading)
I hope the above information helps a tiny bit with regard to DVD formats for this unit.
Mar 12, 2011 | RCA DRC8295N DVD Recorder/VCR
Cd player takes dics in then says no disc
Certain CD players have not been designed to play certain formats of pre recorded audio CDs. Therefore check in your users manual what format of CDs it can play. Play those . Also make sure that CD sits properly in the CD tray with label side up. If the problem persists then you have to call the technician.
Aug 21, 2010 | Technics Audio Players & Recorders
May 16, 2009 | Philips CDR870 CD Recorder
CRV CD Player
The CD player is not designed to play Mp3. You should be recording on to -R discs and use the same format as a standard CD.
Mar 22, 2017 | 2005 Honda CR-V
Philips CDR775 2-Disc CD Recorder Logo
189 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
