Question about Solis Palazzo Espresso Machine
The grinder only starts for half a second and than stops.
I might have to replace the complete grinder unit? Or is it a elctrical problem in the cirquits?
    Problem Solver:
  • 14 Answers
Try a different outlet (not a GFI)
Posted on Feb 13, 2013
Can I replace the grinder in my saeco odeo giro?
yes see the next steps. and fix it. God bless you
  1. Unplug the unit from the electrical receptacle.
  2. Remove the pot and basket. Remove or tape closed the water reservoir lid.
  3. Turn the appliance over and remove all screws that secure the case halves. Lift off the case to expose the heating element and controls.
  4. Inspect the control cavity to determine if the solution is simple: disconnected wire, debris, etc. If so, fix, reassemble, and test. Otherwise, continue with the next step.
  5. Use a DVOM to test the HEATING ELEMENTS and the switch, thermostat, and timer .
  6. Replace any defective parts or decide to replace the appliance, as appropriate.
  7. Reassemble the appliance and reinstall the pot and basket.
  8. Fill the water reservoir approximately half full, then plug in and turn on the coffee maker to test its operation.
Oct 15, 2012 | Saeco Odeo Giro Automatic Espresso...
My Braun KSM 2 has died, suddenly, after about 10 years. Just quit, no noise, nothing. I took apart, looking for a fuse or something to replace and I just see the copper resistance coil and "circuit...
There is a second switch, similar to the user accuated switch, which is opposite the user accuated switch when viewed from the bottom of the unit. This second switch is controlled by a piece of plastic which fails when the device overheats. I am currently seeking to replace that part on my unit.To fix the problem you will need to replace this part so that the second switch is closed. Both of the two switches on the bottom of the unit must be closed in order for the unit to operate.
Sep 15, 2010 | Braun KSM 2 Electric Blades Grinder
In the past I have cleaned the grinder blades 4 times however this time I noticed some of the grind mixture winds up on the counter under the main motor of the unit. When I picked up the grinder and shook...
Have you tried to hoover up the grinds from time to time, from the grinder blades. The coffee beans and ground can gather under the blades from over time. It should not be a problem though.
For better crema you may want to replace the blades.You should replace every 3-6 years. Rancilio Rocky Grinder Flat blades
May 07, 2017 | Rancilio Rocky Doser Espresso Grinder...
2004 kia sodona was stopped at a stop light with a half a tank of gas and than 5 seconds later gas gage read empty and the fuel light came on
This is nothing more than the tank sending unit that has failed. I would look into a junk yard and see about buying a complete unit(pump/sending unit assembly). It will be substantially less than new. Let me know if you need instructions on repair.
Jun 08, 2010 | 2004 Kia Sedona
Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Nov 03, 2009 | Saeco Incanto Sirius Fully Automatic...
I have a Saeco Incanto Rondo with a grinder related problem
First step.If the grind is to coarse the burrs will spin to fast sensing no beans.
Solution: The grind needs to be finer. Caution you can over adjust causing the clay burrs to shatter.
Bruce
Gold Roast Coffee
www.goldroast.ca
Jun 14, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco: grinder stops grinding
Hello, This may be the solution for you: having removed the ceramic grinder to clean out the unit, one of the wires on the grinder had become removed (the "center wire") on the connector. The 2 outside wires were sufficient to give me the illusion that the grinder was connected correctly, however it would only run for a half second and then coast to an annoying stop.
Check all 3 wires that connect to the grinder and make sure they are making contact.
Jun 02, 2009 | Saeco Incanto Rondo
Grinder starts and stops on startup
if this is a cap start motor and not a centrifugal start run motor then bad cap is good place to start
Nov 25, 2008 | Wilton 17202 8" Bench Grinder
Brewing stops mid cycle
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
May 16, 2008 | Saeco Magic De Luxe Espresso Machine
Solis Palazzo Espresso Machine Logo
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
