Question about Garden
Viking me410 electric lawn mower manual
Cord wrapped around motor need details for removal of drive motor
ccrozier_agr
  • 36 Answers
SOURCE: broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Posted on Nov 29, 2008
SOURCE: I need the owners manual for this lawn mower Craftsman 917.377220 6.75 HP
Here a website that gives a list of Craftman Lawn Mowers and it owner manuals. Hope it help, its were I found my manual.
http://www.craftsmanlawn.com/Walk-Behind-Mowers/
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Posted on Apr 02, 2010
Testimonial: "Thanks very useful information.....Many Thanks"
mikehowy
  • 177 Answers
SOURCE: I would like a user manual for a Champion R484TR lawn mower.
google
Posted on Jun 07, 2010
SOURCE: need owners manual
http://www.ariens.com/corporate/pages/customerservice.aspx
Posted on Jul 18, 2010
Can't pull cord to start lawn mower
Either the motor is frozen or the start assembly is jammed.
Aug 12, 2017 | Garden
Pull cord locked up
Can you turn the blade. If not your engine may be locked up, you could just have something wrapped around the blade shaft. You have to look under your lawn mower.
How do i replace the pull starter cord in a Briggs and Stratton lawn mower engine?
3-4 wraps around the pulley, and then the length to the handle.... adjust to maintain a slight tension on the cord by knotting the line in the handle. exact length changes from mower to mower.
Sep 20, 2014 | Garden
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Old Black & Decker 8000 Electric Push Mower
Sorry i think this thing is toast, if the insulation is gone it will fail a flash test, the outer case could become live and will shock you as there is no earth in the cable.
Jun 06, 2013 | Garden
I have a black and decker 18 in lawn-mower. I bought a haeavy duty extension cord to connect power to the lawn mover. It was working then suddenly it stop and blew the switch. I plug the cord to a...
I would say the outlet/ cord. here is a recommended types and lengths of extension cord, Tim:
http://support.mtdproducts.com/app/answers/detail/a_id/435/~/what-type-%26-size-of-extension-cord-can-be-used-with-an-electric-mower%3F
May 29, 2011 | Black & Decker Black and Decker & Grass...
Pull cord is stuck
Take off your cover to the pull cord, the cord probably just got wrapped around the pulley. If you run into trouble with taking off this cover go to smalleng.com they will walk you through the process off pull cord removal and installation. Good Luck PAL.
Jun 11, 2010 | Poulan Pro 22inch 625 Series Briggs ...
How do I replace broken pull start cord?
There are screws holding the top of the mower on, you should be able to remove those and lift them to get access to the cord. From there it is easy. just put new cord back the opposite of the way you removed it, making sure that you get it wrapped the correct direction. you can get a cord anywhere they sell mowers.
Apr 18, 2010 | RTO Toro Lawn Boy 21in Insight Series...
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
We have a John Deere lawn mower model JS45. Just
this problem is related to the auto-snesing carburator. If you wrap the throttle cable, that runs down the left side of the mower, around the handle several times and tie wrap in place the mower will run. I had the same issue with mine. the manual is vague at best when it describes how to fix. After you wrap the cable around the handle, it will tighten the cable and the mower will run.
JV
Feb 28, 2010 | Garden
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
