Question about Electrical Supplies
Need wiring diagram for powerstar plus1200 watt brushless generator
When rebuilding the motor lost markers for reconnection of wires when reassembling
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
pic498
  • 32 Answers
SOURCE: no electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Posted on Jun 13, 2009
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
  • 37 Answers
SOURCE: Would like wiring diagram for starter selonoid for
Hopefully this will be what your looking for if not let me know.
Posted on Nov 22, 2009
  • 3 Answers
SOURCE: plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Posted on Mar 14, 2010
Where can I get a wiring diagram for a 3250- watt generator?
go google and type in-- schematics wiring diagram for watts 3250 generator set-- and if one is available it will be pdf version download
Jan 04, 2016 | Watts Electrical Supplies
My generator will run but barely prodeces enough power to run a fan.
This is a brushless generator, it will not have the charcol things refered to above also known as brushes.. Fire it up and put a volt meter on the 120vac out let. If it is reading 4 to 6.5 vac then the armature is more than likely okay it can be as low as 2.25vac.. Pull the back of the generator off and there should be a large capacitor on the left side with two wires connected to it. If it is leaking or the top is separated replace it. The brushless generator uses the capacitor to excite the magnetic field on order to generate the electricity. It is a simple system with few parts to wear out. Good Luck.
Mar 05, 2012 | Measuring Tools & Sensors
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
Nov 05, 2011 | Generac Guardian Ultra Source 15,000 Watt...
The generator quit working all of a sudden i'm wondering if it could be a faulty capacitor?
Hi and welcome to FixYa, I am Kelly
The BSI550 came in 4 model types 0, 1, 2, and 3.
Types 2 and 3 are brushless. I am assuming this is a brushless generator and the following list of parts can cause the unit to suddenly stop working.
1. Capacitor(s) This unit has _ capacitors
Usually when capacitors fail on a brushless generator you first start noticing that when there is a load introduced that voltage changes dramatically. However they can just up and quit.
2. Diode pack
3. Wiring from the capacitor to the stator is damaged.
4. The Varistor in the rotor has failed (this fails because of a short in the rotor)
5. Rotor short or open
6 Stator winding short or open.
My years of experience with brushless generators is the 2 most common failures (other than wiring that happens alot) are the Rotor and the capacitors in that order. Rotors fail out of the blue... capacitors usually do not. Take a look inside the control panel. If you notice that the bottom of the the end cap enclosure looks like someone dripped candle wax in it you most likely have a failed capacitor. I probe the capacitor(s) with one terminal removed watching for a brief spike in resistance on the meter and then it drifts to infinity EACH time the meter leads are reversed. (Good result usually). After that is is on to wiring, Rotor and stator resistance tests.
Parts:
http://www.ereplacementparts.com/images/Porter_Cable/BSI550-W_TYPE_0.pdf
Thanks for choosing FixYa,
Kelly
Jul 18, 2011 | Porter Cable BSI550 W 5,500 Watt Generator...
THE GENERATOR HAS NO ELECRICITY COME OUT I,TRY NEW CAPACITORS AND DOING THE SAME
if your engine is running ok then adjust the speed control screw, I had a honda generator that lost it's output voltage until i increased the engine running speed screw, i guess there must be some kind of speed sensor!!, i hope this is usefull. COLIN
Oct 18, 2010 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
No ac power from generator
One sure thing is you better find a competent service guy.
It sounds like you have lost excitation to the field of the alternator. Without documentation I can't tell if this is a brushless type or brush type rotor.
In either case, the excitation needs to be restored. On a brushless type, either lack of residual magnetic flux to start the buildup of the field OR failure of the rotating diode(s) can be the problem.
In a brush version, investigate "flashing" the field on Google or trace out why there is no voltage to the field. Possible things for this are failed transformer, failed rectifier, blown protective fuse and or wiring.
Apr 21, 2010 | Briggs & Stratton 12 Kw Automatic Standby...
Generator wont work
The first thing to determine is if the unit is brushless type. If it has brushes, the rectifier module MIGHT be a problem, but more likely is the field has lost its remaining magnetism and needs to be "flashed".
HOWEVER if it is brushless, the field there would require special methods to restart. Search google for brushless generator problem and look for method using series light bulbs and utility power.
NOTE. sometimes a short inadvertently placed on the brushless units will pop the roatating diodes which then must be replaced.
Mar 24, 2010 | Electrical Supplies
Electrical Supplies Logo
284 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
