Question about Samsung RF4287HARS Stainless Steel French Door Refrigerator
Samsung RF4287HARS shows Pc Er on control panel above water / ice dispenser
Already unplugged for 20 mins. Power cord is plugged in again, still showing Pc Er on control panel screen (constant blinking). Compressor is running. Cannot control anything else. Is there anyway to reset the machine?
3 Suggested Answers
  • 400 Answers
SOURCE: compressor is not running, poping sound when electricity supplied
The popping sound could be a direct short circuit, in which case you need to try to see where exactly the sound is coming from. You should then be able to correct it. Second thing is that it is possibly a bad starter relay and can easily be replaced. ratemeplease
Posted on Mar 12, 2009
SOURCE: Samsung Quattro-Cooling RM255LABP Freezer at +20F
orrixcreek i have the same problem. how do you go into the samsung diagnostic? i pressed different buttons at the same time and they're giving me gibberish i dont understand. which specific buttons to press and what exactly do the codes mean? i called samsung and they told me the fridge was probably in "demo mode" that is used on the sales floor and they had me pressed the two left buttons for 6 seconds and a bleep occurred and the LCD went dim. it really didnt fix the problem.
Posted on Jul 20, 2009
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Why my refrigerator panel is showing er rf and the water dispenser doesn't work ?
check the filter for the dispenser it maybe plugged up. As a rule they are located in the front around the bottom of the unit.
Jun 01, 2015 | Refrigerators
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Samsung rf4287hars dispenser not dispensing ice
SAMSUNG RF4282/HARS has a total backwards-double negative on the menu screen ( at least to me ) tho granted, the ice maker is perhaps, lets say, one of the slower cube makers I have ever seen... it has a setting that is .... "Ice Making OFF".... with the option ON/OFF.... make sure that setting is set to OFF if u want ice, or non Orange on the ON screen, or no ice will be made... It could have been worded much better... ie: "Turn Ice Making Off" with option yes or no... but no... My mind says...Make Ice, have options yes or no = just that....if I select YES ... ice making should be on.... not with Samsung... Kinda should go with the other setup settings that Samsung has..... simple yes/no
Words are.... ( selection )
"Ice Making OFF" setting should be set to OFF... just to do that... you are turning the shut down mode OFF and u will be making ice ( you are turning the shut down ice making function OFF in common terms)
As expensive as this machine is.... It should be easier and programing should restore after a power flux.... anyone wanting a lot of ice... forget this machine... we continue to purchase bagged ice and keep it in the freezer in the garage, it can\'t keep up on a daily basis.... I continually have to re-enter my WIFI passcode at every power outage... ( sometimes a lot in summer with storms )
My wife wanted it.... steel look.... she now finds she hates keeping it clean... NEVER AGAIN.... Samsung has some great products, but we have to suck up on this one... never again
Feb 27, 2013 | Samsung RF4287HARS French Door...
Ice dispenser problem Samsung rf4287hars
Check that you ice maker is on, do you have ice in the bucket?
Check you ice drain is not plugged. Do you hear some humming noise when you push the ice dispenser? This could be a complex problem.
Feb 27, 2013 | Samsung Refrigerators
Samsung rf4287hars ice dispenser doesn't work
The whole unit must be removed and unplugged. There is a screw in the bottom near the dispenser opening. Remove this screwn and then take a butter knife and start prying the unit outword.
The lever that operates the microswitch may be broken and was on mine. This part is cheap plastic and breaks when over entended in the least. If the actuation lever is broken, you will NOT feel any resistance when pressing the Ice despenser and will push on through to dispense water. Problem is there is NO fix for this except replacement and Samsung will not pay for it.
I fashioned a piece of bailing wire in place of the lever that will act the same and have a little spring incase someone presses to hard with their cup/glass. Yes... its bailing wire and works great. You must drill through the middle of the broken support, fashion the wire, coat with super glue and put in position pretty quick. 43e0da13-0ab4-425d-8cad-f17e16cccb58.jpg
If you find a small plastic piece on the floor and your ice maker stops dispensing.... I think I know your problem.
Oct 06, 2012 | Samsung RF4287HARS French Door...
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
I have a samsun fridge and the code pc er came on and the light is not working nor the temp why????
"PC-ER" its a error in the PCB (computer).
Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
Samsung says that... if the code "PC-ER" appears on the display panel or if you cannot resolve the issue, the refrigerator needs to be repaired. Contact a Samsung service technician.
Hope this helps.
Jun 09, 2011 | Samsung Refrigerators
I have a Samsung RF4287HARS. I opened the refrigerator compartment doors and the lights did not come on. Same condition for the freezer. I believe that the unit is operating (as i could hear the faint...
Pc code is saying there was a momentary power loss. Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
If after all of this you still have issues with the lights or the unit is not working properly just repsond here and we will help you.
Thanks for Choosing FixYa. Kelly
Sep 29, 2010 | Samsung Refrigerators
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Samsung RF4287HARS Stainless Steel French Door Refrigerator Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
