Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
RESET ERROR CODES
TV DOES NOT GO ON
    Top Expert:
  • Sony Master
  • 14,553 Answers
If it does not come on there is not a way to reset the error buffer.
Posted on Dec 22, 2012
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Where is the reset button on my WD-60737 tv
you have no reset button per-se. To reset the unit, unplug from AC outlet for one minute, then plug back in. If you still have some issue with it, it is important to give some clues. Are you getting error code lamps blinking. Any response from unit at all.
To read error code the lamp or lamps (LED on front of unit) may blink momentarily, then another series of blinks. you must count the blink series.
may blink once, pause then blink twice, then repeat that series. that would be a code of 12, which is no error found.
may blink 5 times, pause then blink 7 times, then repeat that series, that would be a 57 error code, meaning ballast communication problem.
There are several other error code possibilities, so it is important to be able to convey any error code in order to be most helpful.
Jan 16, 2015 | Mitsubishi Televison & Video
Canon image class all in one 4412 printer error code e-202-2002
Same problem on an older LC-C3742U SHARP AQUOS. Other tv in my house receives ch 4.1 at the same cable spot and bad tv will not receive this ch in the good tv's spot so I know it is the tv. It receives all other channels well just not 4.1 which shows E202.... Tried your reset protocol but it merely started the tv and held the channel it was last set on.
For more help visit cbr tech solutions
Apr 20, 2014 | Office Equipment & Supplies
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Need to reset v-chip code JVC t.v. vcr combo 2000
I got a jvc tv-13142 at a pawn shop but some of the channel is blocked and i need a vchip code to unlock it i try all zeros and it show error how do i reset code
Jan 22, 2010 | JVC TV-13142 13 in. TV/VCR Combo
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Tv says airflow restriction tv will turn off. there is no airlfow restriction
I did not find a reference to airflow restriction in the service manual.
I don't know if this will help, but here are the error codes:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
4. Error Codes
The Error Code designations are listed below:
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Oct 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
TV CODE
need password
Apr 08, 2008 | RCA 27R410T 27" TV
ERROR CODE 34 on Mitsubishi TV
I just had the same issue with my TV (dont know code), but the issue was with the power supply.
Feb 16, 2008 | Televison & Video
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
