Question about Motorola Cell Phones
Is it possible to get my phone to turn on, on my motorolaMB855 that has no power button?
My motorola MB855 has no power button it got broke and will only turn on to thr battery charging screen after i plug it into the charger does anyone know how to get it past that screen so i can use it?
  • Motorola Master
  • 641 Answers
Well this is not the recomended way,but if you use a tooth pick,nothing metalic, and where the power button was,stick the tooth pick in and press the little switch.youll feel it click.
Posted on Dec 09, 2012
SOURCE: Doesn't turn on!!
I have the exact same problem with my E815 Motorola...only had a month or two, forgot to charge and battery went dead. Now moto screen comes on for about a second and dead? Try to get to boot loader, same thing...dead.....Bob
Posted on Feb 15, 2007
SOURCE: Motorola E815 - Battery Charger
The E815 has a very poor design on the charger port. The cleaning that Solution #1 referred to is that Verizon cleans the contacts of both the phone and the charger using rubbing alcohol on a toothbrush to clean both the phone contacts and the charger contacts. I have to do this once a week or so to keep my phone charging. The rubbing alcohol dries quickly and will not harm the phone. Motorola has changed the charging ports on the newer phones because they recognize that they have a problem with this design. I have also turned in my phone to Verizon (twice) for a replacement. If you replace the phone be careful to record ALL your contacts because when Verizon transfers your contacts from the old to the new phone the speed dial numbers all get messed up because they start their numbering differently than you had it. I am still repairing my speed dial numbers. Hope this helps.
Posted on Sep 07, 2007
Bajanguru
  • 7752 Answers
SOURCE: my L6 i motorola/ charcoal color phn
have the firmware reflash on the phone and that will take care of the issue...you are having
Posted on Feb 17, 2008
SOURCE: Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Posted on Apr 25, 2009
SOURCE: Motorola Hint QA30 won't turn on/Motorola screen flashes
Same problem here!!! I was in the middle of a text and it shut down outta no where then i turn it back on and it just flashes the purple circled M at me....I dont have a warranty on my phone but luckily I called alltel and they sent me a box to send the phone back and they are replacing it free of charge. I love the hint its my favorite phone of all the phones ive had....alltel always satisfies its customers in the end and ill definatly give the hint another chance...bottom line...call alltel have them send you the return box and mail it to them wait a week and you got a new phone!! good luck!
Posted on May 26, 2009
How might I fix or remove freezing/hanging issue with both factory installed and playstore apps and wigets on an unlocked motorola mb855 running android 2.5 without use of a computer and free?
here
You can try to restore the Motorola Photon 4G MB855 like this:
  1. Enter into your phone settings by pressing the Menu button.
  2. Choose Settings and then select Privacy.
  3. Now select Factory Data Reset and then choose Erase Internal Storage.
  4. Lastly, select Reset Phone.
motorola-photon-4g-mb855-hard-reset-300x279.jpgFor those that are unable to use the Android system, mainly because the phone refuses to boot normally, you can try to restore the MB855 using the recovery menu. Here's how it's done:
  1. Turn off your phone and then press and hold the Volume Down Button.
  2. While holding the Volume Down button pressed, tap on the Power Button and the Fastboot menu of the Android system should appear on the screen. This is the point where you should release all buttons.
  3. Use the Volume Down key to navigate through options and when you see "Android Recovery", chose it by pressing the Volume Up button.
  4. Once the triangle sign appears, press both the Volume Up and Down keys, at the same time.
  5. In the newly appeared menu, navigate using the Volume buttons to Wipe Data / Factory Reset, and select this option by pressing on Power.
  6. Confirm your option by selecting Yes, once again with the Power button.
  7. Wait for the process to complete and reboot the phone.
gooluck...
Jun 21, 2014 | Cell Phones
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
Galaxy Samsung tab 10.1 won't turn on
you had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
Mar 22, 2013 | Tablets & eReaders
I only have had my Motorola Z9 for two weeks and it just turned off of me the other day, when it had a full charge. I tried taking out the battery and putting it back in and keeping it plugged into the...
try taking the battery out plugging in the phone to the charger see if it turns on if it does then plug in the battery . let me know if that worked i have other ideas but thats a start
Mar 26, 2011 | Motorola Mobility Z9 Cellular Phone
The screen on my phone went completely black and will no longer turn on from what iv tried i cant hear or seen anything and there is no sighn of water damage what do i do?
I will try and keep this short. I have a Motorola Razr (puchased in the USA..... this will make sense later) and I lend it to my brother when he visits me from Canada. (Roaming charges for Canadians using their phone in the US is insane) He too has a Motarola phone that he brought with him. The Charger that he brought with him was for a Canadian phone. Apparently, you cannot use a charge for a Canadian phone, on a USA contracted phone..... I'm not sure why, but it is the case. He attempted to charge my USA phone with his Canadian Charger and the screen went blank. The phone was still on and could even receive calls. Even when the calls came in, the screen still remained blank. I won't bore you with any more details.
Here is how I fixed it:
- Unplug phone from Canadian Charger
- Take the battery out of the phone.
- Plug in USA built charger (without the battery in the phone)
- The phone attempt to charge
- Screen should turn on. Wait till screen indicates (Cannot charge battery)
- Plug battery in.
- Hold down power button to turn on the phone.
- Phone should be in working order.
I don't claim to be an expert. This may only apply to my particular situation. Hope it helps if you happen to use the incorrect charger. Take care.
Mar 22, 2011 | Motorola Mobility RAZR V3
Moto Q Sprint Phone wont turn on
3 ways to solve it:
1.) Take out and put battery back in.
2.) Plug into a wall or car charger but not a PC USB charger. This does not work with PC USB connection for some reason.
3.) Hold red on/off button to force a reset.
4.) The big battery icon should appear on screen.
5.) Let charge until mostly or fully charged.
7.) Turn on phone. It should boot.
2 - Hard Reset
To perform the hard reset, hold down the center select button in the middle of the D-pad/joypad (the raised silver one.) Then, continuing to hold it for at least five seconds, press the power button to allow the device to power up. Continue to hold the select button until you get a screen which asks if you want to perform the master reset. Let go of the select button, and press the appropriate soft action key to respond yes.
REMEMBER! A hard reset erases ALL of your data!!! This is why the Backup is so important.
You could get Sprite Backup. In addition, install it to your Storage Card and save your backups there as well. That way you can restore on the road without a PC.
3 - Update your phone's firmware
Feb 11, 2009 | Motorola Mobility Moto Q
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Magellan maestro 4040
plug the unit in and press the silver button by the left side and make sure the unit is fully charged if not,plug in the home charger and iti will be fully charged 3 to 4 hrs,also if the battery is fully charged the unit should turn on after you press the silver button on the left side and hold for a few secs. without the car or home charger.also chk your cd manual for further info.let me know what happens.ok.
Feb 27, 2008 | Magellan Maestro 4040 GPS Receiver
Charging problem!!! PLEASE READ!
as i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
Feb 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
PDA would not turn on...
try to charge it for longer time, then try to turn it on, i'm not sure that its gonna work.
Jul 24, 2007 | Dell Axim X51v Pocket PC
Cell Phones Logo
60 people viewed this question
Top Motorola Cell Phones Experts
270rexton
270rexton
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
