Question about Crosley CDE6000 Electric Dryer
Troubleshooting crosley dryer thermal fuse - Crosley CDE6000 Electric Dryer
  • Official Brand Answer
  • 4,342 Answers
Hello - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install/remove for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
Posted on Dec 14, 2012
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
onthejob5130
  • 640 Answers
SOURCE: crosley dryer
check your breaker i think you losted a leg...this is a 220 dryer,,make sure you have true 220..keep me posted on the job...
Posted on Feb 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: crosley dryer fuses where r they
The thermal limit is located on the right hand side of the heater chamber. The dryer will not run if it is open. SOME REPAIR PHOTOS
Posted on Sep 06, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Crosley CDE 7000 dryer that stopped heating
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it will help you find the thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 06, 2010
  • 18 Answers
SOURCE: where is the thermal fuse for a crosley cde6500w
The thermal fuse for this dryer is located on the right side of the heating element behind and near the top/left of the drum. You will see two white wires leading to it. The Thermostat is right above the heating element - two red wires lead to it.
Posted on May 27, 2010
Crosley CDE8000gbl can not find thermal fuse part number
-Check With reliable part . They should be able to give you part number.
Good luck
Mai
Dec 14, 2013 | Crosley CDE6000 Electric Dryer
My dryer wont start at all. what could it be? a thermal fuse?
It could be either the thermal fuse or the door switch. You can check the door switch usually by just pressing it in and listening for a click to know that it is engaging. Here is a link to replacing the thermal fuse.
http://www.partselect.com/PS345113-Whirlpool-3392519-Thermal-Fuse.htm?SourceCode=1&SearchTerm=CEDX631VQ1&ModelNum=CEDX631VQ1
Sep 05, 2012 | Crosley CEDX631VQ Extra Large Capacity...
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Where is the thermal fuse for a crosley cde6500w
Apr 14, 2010 | Crosley Dryers
Crosley dryer fuses where r they
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Crosley dryer-model # cde6500w
I believe that you probably purchased a kit of fuses which provides fuses for several different types of dryers. That way the parts store can sell you the kit without knowing exactly what type of dryer you have. If I am right about this, there is no yellow fuse in your dryer, you will need to buy a new one to replace the red dot fuse. Also, you will want to find out what is causing it to blow again so quickly, probably your exhaust duct is a little plugged, causing the inside chamber to get too hot.
Dec 27, 2007 | Dryers
Heating element in Crosley Clothes dryer
Before you replace the heating element, check the thermal fuse. All heaters have safety thermal fuse. This opens in case the thermostat fails. This is normally attached on or near the heating element, looks like diode. (When replacing, do not solder ! this will damage the fuse)
May 30, 2007 | Crosley CDE6000 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
46 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
