Question about Indesit WA 115 Front Load Washer
All green lights stuck on carnt open door on wia 191
Stop alarm goin off
Pull the fob apart. It will open up and you can push the button back in place. No other options unless you have a second fob. If you do, remove the battery from the bad fob and only use the second fob.
Oct 16, 2016 | Cars & Trucks
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
HOW DO YOU PUT REFRIG IN DEFROST MODE WHEN IT HAS ELECTRONIC DEFROST CONTROLLER
You didnt give the make of the ref.; But your solution is here for most all
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, see picture...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. A close up common way *this* version of the Maytag/JennAir control is wired.
Amana also has a version of adaptive defrost, see info sheet for some help on the Amana version. Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A ?¿½d?¿½ in the freezer temperature window and ?¿½F?¿½ in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. ?¿½d?¿½ and ?¿½F?¿½ will be displayed until the defrost cycle is complete. (approx. 8 minutes)
For some Whirlpool refrigerators - some Kenmore refrigerators are made by Whirlpool ( 106.######## )
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
?¿½ If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
?¿½ If the relay clicks two times, check for an open bimetal.
Maytag S-S Refrigerator MSD2756GEW forcing defrost cycle
I replaced my defrost heater two weeks ago, but the frost built back up on the evaporator coils. Replaced the adaptive defrost board with new ( Maytag p/n 6100598 8 ) board. Want to force a defrost cycle to see the heater work, so I shorted the L1 pin to adjacent pin (now called DOOR instead of TEST) for three seconds and nothing happens. Compressor keeps running, fans still going etc. Tried pressing the door switches 5 times in 6 seconds and that doesn't work either. Any hints on how to get the defrost cycle to initiate?
This might help, a copy:
The issue is that some 12002104 ADC boards have been shipped in the 61005988 ADC board box. Do not reorder the board, the 12002104 board will function the same in place of the 61005988, but you must use the forced defrost method for the 12002104. Jumping "L-1" and "door" will not initiate the forced defrost function.
To Initiate Forced Defrost Cycle:
Cycle cold control on and off three times in six seconds. The cold control needs to be left in the closed (call for cooling) position for the defrost system to energize on all platforms. It is not enough to cycle the cold control knob, the contacts must actually open and close (open doors for a period of time if necessary to force the control to call for cooling). In most cases, you can hear the contacts open and close if they are doing so.
To Terminate Forced Defrost Cycle:
Disconnect power for five seconds.
You were right. I cycled the cooling controls three times and it went into a defrost cycle. Thanks.
Aug 08, 2011 | Refrigerators
Liftmaster 1/2 horse Model HBW0777 acts like the safety sensor is stuck (door won't continue down - re-opens when you let go of the wall button. I can close it with the wall button but I need to hold it...
If the main light flashes 10 times when the door reverses it is a door sensor problem. Look closely at the green lights to make sure one isn't flickering ever so slightly. Tweak them a bit.
Mar 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
HAVE JUST AQUIRED WIA 111 without hand book. How
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Not sure what you mean by ‘turn off lock’. If you mean the door lock light is on or flashing this may indicate a fault, in which case you would have other lights flashing as well to indicate what the fault is. Click on this link for Hotpoint, Creda and Indesit error code definitions or if you need a free user hand book then click on user manual and select your manufacturer.
Mar 06, 2010 | Indesit Washing Machines
The small green LED light on garage door motor head out
That little green bulb just flickers when the logic board is receiving a radio signal and is also used to send a code to assist with diagnosis. It does not keep the opener from working. You say the door is 'stuck'. If it is stuck in the open position the trolley may be jammed against the bolt just in front of the motor unit. If so, loosen the chain to relieve the pressure and the opener should run. When the door is closed locate the 'up limit' on the side of the motor unit and turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Then tighten the chain.
Mar 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opened and will not close or open now
Drive should have a feature to disconnect from door to allow for manual closing.
Jul 15, 2009 | liftmaster Chamberlain Garage Door Opener...
Indesit WIA 101
to open do power off after 5 min open the door with power off
Jul 27, 2008 | Indesit W 123 Front Load Washer
The cd door is stuck - i cant open the door or close it, help? Tray does not open when switch is depressed. Green light burns steady.
http://video.about.com/pcsupport/Open-a-Stuck-Drive-on-Your-PC.htm
First, you'll need a paperclip. Unfold it so there is 1 to 2 inches that is straight.
Now, look closely at your drive door. There should be a very small pinhole either above or below it.
Insert the paperclip. There is a very small gear that when rotated, will manually open the drive door.
Retract and reinsert the paper clip as many times as it takes to eject the drive enough so you can hold onto it.
Pull Out the CD or DVD Drive.
Now slowly pull the drive out until it is fully retracted. Remove your stuck CD or DVD, and slowly push the drive bay back until the door is closed.
Apr 18, 2008 | TDK (DVD+RW47BXS5) Storage Media
Indesit WA 115 Front Load Washer Logo
52 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
