Question about GPX 19 In LED HDTV - TE1982B
How to I get FIOS to work with my GPX TE1982B
I Unhooked my old TV to my FIOS and put the Red, White and Yellow plugs into my new GPX TE1982B, Turned it to Channel 3, Made sure input was TV, set for Cable...but can not get anything except a blue screen and a box that says scan for channels...in which Verizon has told me not to do, they also tried to get my remote to work, but they said they do not have a code, and the steps they used for TV's without Codes does not work either? HELP??!!
  • 13 Answers
SOURCE: CODE NUMBER FOR GPX TD4022 HDTV TO VERIZON FIOS REMOTE
You can usually call the manufacturer of the remote & they will give you the code needed.
Posted on Jun 24, 2012
Testimonial: "No code for the model i bought yet,in the future."
SOURCE: what code do I use for my 20.0 dish network remote to use with my gpx tv
You need to call dish. I just did this last night. Took them less than 5 minutes
Posted on Oct 06, 2012
jerry_kramer
  • 3904 Answers
SOURCE: source code for a gpx tv
My only suggestion is to look up GPX on some remote control code sites. I have not heard of GPX as a brand name but I bet it has a parent company that is more recognizable. Most remotes have an option to them to do a manual search which makes you go through all known codes to find it.
Posted on Oct 08, 2012
emissionwiz
  • 76070 Answers
SOURCE: Does anyone know how to run a channel scan on a gpx without the remote?
You must have the remote to do this function. To buy a compatible remote go here. www.remotes.com
Posted on Nov 11, 2016
emissionwiz
  • 76070 Answers
SOURCE: Gpx tv how do I scan the channel without a remote
You can't. To buy a factory remote try here. 1 800 Remotes
Posted on Dec 09, 2016
How to connect the fios
You can use a coaxial cable direct from the fios router to the TV. If you have a cable box converter then you can use S Video cables Red White and yellow, low quality, or component cables Red green and blue but you will also neeed audio which would be a red and white pair so 5 cables in total, better quality and finally an HDMI cable just one connection but high quality. The last is the most expensive and make sure to get the right length to reach the TV from the converter box
Good Luck Ed Pinero
Feb 02, 2013 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
I watched two movies on my brand new GPX D1816 and when I went to watch #3 the audio works but the video does not. As a matter of fact, I can hear sound, but only when the yellow video cord is not...
try to put the red (or white) cable an see what is happend, try whit movie #1or2, if is not ok you must contact the service for this apliance who is in your area.
Feb 14, 2010 | GPX D1816 DVD Player
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
How do i hook dvd player to tv..i know its probably simple
The yellow and white cables hook into your tv inputs
Jan 19, 2009 | GPX D1816 DVD Player
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
How do i connect my GPX dvd player to my hd tv? I have Direct TV also.
I also have a GPS DVD Player and Direct TV. On the back of the TV there are slots for AV1 and AV2, I chose AV1. The yellow cable is your video.When placing the YELLOW in the video I noticed the pic was Black and White. After changing it to the slot marked Video Y the color came back. The white and red are audio. I put the WHITE in Audio L and the RED next to it in Audio Pr. Granted I am using a Phillips TV but the concept is the same. Hope this helps. If you don't have sound, switch the position of the Audio (red and white) cables.
Apr 05, 2008 | GPX D1816 DVD Player
Hooking up the dvd player to the new tv
No you don't need them. The red, blue, green wires are component cables for HD.
Jan 26, 2008 | GPX D1816 DVD Player
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
Remote codes for Ilo tv or gpx dvd player
i have universal remote and tv gpx soi need thecodes
Sep 19, 2007 | Televison & Video
GPX 19 In LED HDTV - TE1982B Logo
16 people viewed this question
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
