Question about Nisca PR5300 Duplex Card Printer System - 2 Year Warranty
Ribbon Wind up miss 1B-01 plz help
Plz help me with this i have a PR5310 and it breaks the ink ribbon
My nakajima Ae-170 is not showing full ink on letters i type in
Wind the ribbon up exposed ribbon not used for while wil have voids in the characters.
Feb 07, 2017 | Nakajima Office Equipment & Supplies
How do I make ribbon advance?
check to see if it is in stencil postion on ribbon lift lever
Aug 30, 2014 | Smith Corona Office Equipment & Supplies
I have a royal 2000 typewriter the ribbon keeps getting tangled up.please advise
You may have the ribbon installed wrong. About 95% of typewriters with fabric ribbons wind to the outside but a few wind to the inside. Type with the ribbon off and watch the take up ratchet and installthe ribbon so it winds that way
May 02, 2011 | Royal Office Equipment & Supplies
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
I just installed a new ribbon on my olympia deluxe and the ribbon keeps getting loose. Could that be because I installed the ribbon wrong? What could be the problem?
You probanly installed it wrong. Most T/W's spooled ribbons wind to the outside of the spool, however there were a few that wind to the inside. Withe the ribbon off type & watch the spool mech. install the ribbon so that it will wind onto the spool.
DickyO
Nov 09, 2010 | Olympia Office Equipment & Supplies
Eurovox max down codes plz 18/02/09
Codes for 5c01 on 18 feb 2009
First line 0B F2 52 72 4E 1B 86 90.
Second line unchanged.
OK.
Feb 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Brother intellifax 770
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 25, 2008 | Office Equipment & Supplies
Ribbon empty
Winding technique:
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
IBM Easystrike Cartridges
The ribbon cartridges can be pried apart they are pressed together, getting it apart is easier than putting back together.
Next time you have to install a ribbon advance it by hand for a foot or so as old ribbons tend to stick to themselves.
Hope this helps
DickyO
Feb 08, 2008 | Lexmark Wheelwriter 3 Typewriter
248 people viewed this question
Top Nisca Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Nisca Office Equipment and Supply Expert? Answer questions, earn points and help others
