Question about Wharfedale Moviestar 70+ System
Can I connect an Onkyo HT-R508 amp (8 ohms) to a Wharfedale Moviestar 70+ (4 ohms) speaker system?
I have recently bought an Onkyo HT-R508 amp which has a rating of 8 ohms and a Wharfedale Moviestar 70+ speaker system with a rating of 4 ohms. Is it safe to connect this?
4 Suggested Answers
SOURCE: Wharfedale Moviestar 60+...
witch company your sub woofer. aleredy company has given user manuval see connections in manuval okkk
Posted on Mar 15, 2008
VOTIT
  • 2071 Answers
SOURCE: dont know how to connect
Just click and choose whatever hooked up connection you want; DVD Players/Recorders: Home Theater Setup, Installation & Hook Up .. * Audio and Video Connection Guide * What is HDMI Technology? * HDMI Explained in Detail * Audio and Video Definitions Plasma or Video Projector Wiring Guide Blue-ray Surround Wiring HP TVs - TV Cable and Connection Types Hope this may help; Regards, VOTIT
Posted on Jun 08, 2009
venexcsd
  • 1185 Answers
SOURCE: Hi there Could somebody please
The speakers are rated at 20 watts rms (Root Mean Square)
The 8 Ohm impedence is applied so that the driver on the amp is balanced and lowering the impedence can cause them to fail as they overdrive.
As Wharfdale have worked out the dynamics of these speakers very carefully I would apply their logic of putting the right Ohmic value on the end of them.
I would not Daisy Chain them as this will lead to reduced performance anyway
By Wharfdale selecting cone magnets and cones that match they do not need loads of welly to give their best
Yes your Yamaha will if applied full throttle could damage them but then there are amps out there that would blow up most speakers unless they were designed for that load
You could contact Wharfdale direct and ask them for their spec sheet
http://www.wharfedale.co.uk/Support/
Posted on Nov 30, 2009
How do i connect Wharfedale 9.5 speakers to onkyo HT- R538 home theatre system
Take a look at the setup procedure. Your Onkyo may allow you to select speaker size and distribution of bass, etc
Dec 26, 2012 | Wharfedale Audio Players & Recorders
I have a Onkyo Model HT-S5300 I can to install two additional front speaker I want to know the speaker specification that i can install
The speakers and amp are optimized at 6-ohms. Adding speakers will require you to run them in parallel with a possible dangerously low impedance; or in series, doubling the impedance which is safer.
These products are not designed to be modified.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/search?q=Onkyo+Model+HT-S5300
Specs page 58-59.
Apr 24, 2011 | Onkyo HT-S5300 Theater System
Hi ther i was wondering the max power i can put through my gale moviestar bookshelf speakers? i have them as mt main speakers on a sony av amp mod- TA-VE700
realalema60,
The main speakers can handle up to 120 watts and the satellites about 60 and the center near 90. As long as the speakers are 8 ohm rated, you have no issues with your receiver over powering them so play away.
-Chris
Aug 08, 2010 | Gale Moviestar 5 System
Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
May 24, 2010 | Onkyo M-282 2-Channel Amplifier
Does onkyo HT-s3100 supports 4 Ohms speakers from JBL(control 1)
Palaboy is incorrect. JBL Control 1 speakers are 4 Ohm 150 watt speakers. He's probably thinking of the Control 1x speakers which are 8 ohm 80 watt speakers.
If you hook your Control 1s to that Onkyo, it won't sound great and could cause the receiver to overheat and trip the protection circuit if played at high volume.
Aug 11, 2009 | Onkyo HT-S3100 Receiver
Dont know how to connect
Jun 08, 2009 | Wharfedale Moviestar 60+ System
Wharfdale moviestar 70 speekers and sub
i have the same moviestars 70+ plus a yamaha rx-v750 put the crossover on the sub to maximum (left knob) volume (right knob) about 2/3 clockwise. change the crossover on the yamaha to anywhere from 80-120 ( the 120 will put more bass to the sub) if your yamaha has sub level/volume control set it higher, also if it has LFE/sub out set it to sub only.
Dec 17, 2008 | Wharfedale Moviestar 70+ System
Cutting off and stayin in Stand by mode
To me it sounds like you might have blown a channel(s). The speakers that you are using with unit, did they come with it? If not you need to check the ohms of the speakers. It looks like the Onkyo HT-SR800 can only handle a minimum of 8 ohms. If your unit is under warranty definately send it in for repair
Jun 03, 2008 | Onkyo HT-SR800 System
Mar 12, 2008 | Wharfedale Moviestar 60+ System
Wharfedale Moviestar 70+ System Logo
78 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
