Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My rca d52w20 projection tv wont turn on
The power buton comes on then goes off  . it does this 3 times then goes off. this tv has been hardly used is this a easy fix ?
    Scholar:
  • 87 Answers
It could be as simple a 3 capacitors in the power supply.Location CP120,CP140 and CP114.
Posted on Jan 13, 2009
My 52 in.rca rear projection hdtv tv . i have a hard time turning it on. i keep pushing the power on the remote and tv it will come on and turn off 3 times. i stuggle with it for about ten minutes. then...
no its most likely failed power caps CP150, CP120 and CP114 capacitors on the deflection board are the usual cause of that symptom. You can get the RCA repair kit by the same name from www.tvrepairworld.com under the RCA repair kits category.
Sep 04, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on the green light comes on for a second or two then goes off then comes back on and does this 3 times
Replace swolen capacitors on the deflection board.If caps ok remove deflection board and send to PTS for rebuild. Board is no longer available.
Nov 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have rca d52w20 rear projection hdtv moniter-does not come on
i just changed the 3 capacitors cp150 2200 16v and cp114 35v and cp120 35v. the set seems to working good now. not to hard to do if you know how to solder. take the back off the tv and they are on the board that is on the bottom left.
Jan 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
