Question about Olympus FE-330 Digital Camera
I have olympus fe-330 camera but i lost the usb cable.how can i transfer pics to my laptop?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Dec 09, 2012
  • 919 Answers
SOURCE: Olympus SP550UZ photos saved on camera memory not card
In the Menu if you go to the option that says Setup and press ok there should be an option that says Backup. This should allow you to copy the images from the internal memory to your xD card.
Posted on Dec 10, 2008
  • 919 Answers
SOURCE: how to connect my olympus fe-360 cam. to laptop as webcam
Unfortunately this camera is not capable to be used as a webcam. It is only to be connected to the computer when you want to download images from the memory card to the computer.
Posted on Mar 09, 2009
SOURCE: Problem transferring photos from my digital camera to my PC
Be sure that you plug original Olympus USB cable directly into USB port on mother board (ussualy on the back side of PC) not on the front pannel hub and not into extention USB cable.
Posted on Mar 23, 2009
guru_dev
  • 315 Answers
SOURCE: How do you transfer pictures from camera Olympus FE-20 to compute
one of the manual must help you.... if it does dont forget to rate!!! http://www.olympusamerica.com/files/autoUSB.pdf
http://www.olympusamerica.com/files/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
Posted on Mar 25, 2009
iwctoys
  • 126 Answers
SOURCE: Can you trickle charge the Olympus FE-20 via the usb cable?
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Posted on Jul 02, 2009
I have an Olympus FE-330 camera. When I try to transfer using the Olympus Master 2 (recently installed) it says 'software unable to locate an Olympus Digital Camera connected to a USB port' I...
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
Jun 15, 2011 | Olympus FE-330 Digital Camera
Hi i have lost my disk to my FE-330 is there a free download so i can download pics from my camera to pc? Thanks
You can download Olympus software from
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1373
You might want to consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Jan 13, 2011 | Olympus FE-330 Digital Camera
I put the xd picture card in my laptop and unable
Try to use the usb cord that came with the camera to transfer photos over. Don't forget to install the driver for your camera.
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1351
http://www.olympusamerica.com/files/oima_cckb/FE-310_X-840_C-530_Instruction_Manual_EN.pdf
The 2nd link is the manual in .pdf form, and there should be a usb cable that came with your camera and if you lost the cd-rom then you can download drivers for free from the olympus support site (1st link).
Good luck on retrieving your pictures.
Jul 29, 2010 | Olympus FE-310 Digital Camera
Olympus fe 4000 - when plugged into the computer doesnt work
Is the computer or the camera telling you the battery is bad? If it's the computer, you might have some bad pins on the camera, or your usb cable may have a problem with it. If the camera is reporting this on it's screen, not sure what the problem is there. I would instead, just transfer the pictures to the computer via a card reader through the USB port. Check your printer- many printers these days have memory card slots on them, and you can transfer pics to the computer through them.
Apr 12, 2010 | Olympus FE-230 Digital Camera
Can I transfer photos on my computer back to my camera memory card?
Hi friend,
Yes you can....you tranfer photos between computer and camera. but you need to be use cable for it..otherwise you can't transfer data without cable
Dec 20, 2009 | Olympus FE-330 Digital Camera
Can another brand chord be used to download pics?
Your camera uses a standard USB-to-miniUSB adapter. If you want to get a new cable (or you might have one at home), it should look like this:
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 26, 2009 | Olympus FE-190 Digital Camera
Download pics onto computer????
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
(http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version).
Mar 12, 2009 | Olympus FE-330 Digital Camera
Lost USB for Olympus Camedia C-480. Where can I buy a new one?
yes you can buy the new usb cable from canon store or you can try memory card reader
Jan 26, 2009 | Olympus Camedia C-480 Zoom Digital Camera
Olympus camera fe 240
You can transfer the photos directly from the camera to the PC using the USB cable that came with the camera. You don't need to transfer the pics to memory card first.
Connect the cable to the camera and the PC. Turn on the camera and your PC will recognise it as an external storage device. Use the PC's software to transfer the photos from camera to PC.
Once you have the pics on the PC you can use the Olympus Master software included with the camera to edit and archive the photos on the PC.
Mar 13, 2008 | Olympus FE-240 Digital Camera
Olympus FE-330 Digital Camera Logo
59 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
