Question about Seth Thomas Home
Need a replacement tank for a St Thomas Creations Berkshire toilet which has been discontinued.
The tank cracked while trying to remove the flush lever which still won't come off! Now I need a new tank. How do I find a compatible tank? Does it have to be from St Thomas Creations or can I use a tank from another company?
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Posted on Jan 18, 2009
  • 297 Answers
SOURCE: Cheviot Wall hung toilet flush valve replacment gasket
try a plumbing supply co. they may help you
Posted on Jul 14, 2009
  • 37 Answers
SOURCE: St Thomas Barrymore model toilet bought
Look into the cistern to see if the plunger is stuck in the OPEN position.
Posted on Oct 09, 2009
bearsfan7538
  • 119 Answers
SOURCE: need diagram of toto toilet tank inside have
You need to replace the fill valve
Posted on Nov 15, 2009
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Posted on Jan 15, 2010
How to adjust water level in a toilet
most toilets have a adjustment screw on the fill value....screw in or out to adjust water level....try this a few times to get proper height...
Jun 19, 2014 | St. Thomas Creations 6201.024.02 Marathon...
Tank refill sound
The diaphragm is worn out in the valve assembly. Replace it and that should do it.
Jan 21, 2013 | St. Thomas Creations Neo-Venetian II...
I need a replacement flapper for a St Thomas Creations enhanced height elongated 1 piece toilet
Did you try to find a replacement flapper by specifying the toilet model, or did you show them what you have? If this is not a power assisted flush toilet, there aren't that much difference between flappers. Worst case you could replace the whole flush valve assembly with a generic type.
Oct 18, 2012 | Seth Thomas St. Thomas Creations 6006.130...
The tank is not filling with enough water. its about 1 1/2 inch below top of tube.
At the top of the float arm there is an adjustment screw to set the water level.
Mar 06, 2011 | Seth Thomas St. Thomas Creations 6006.130...
Water level is going down, in tank. How do I adjust?
Try this link first. It will not give you the answer but gives you an email address that I would expect would be of help.
http://www.stthomascreations.com/CustomerService/
May 31, 2010 | Seth Thomas St. Thomas Creations Daytona...
Toilet keep losing water
You need to have your rubber flapper and/or valve replaced. OR...It's possible yours is getting hungup on something and not seating in place after flushing...check to make sure that's not the issue.
Nov 10, 2009 | Seth Thomas St. Thomas Creations 6006.130...
Home Logo
24 people viewed this question
Top Seth Thomas Home Experts
Austin
Tom Chichester
William Smith
William Smith
Are you a Seth Thomas Home Expert? Answer questions, earn points and help others
