Question about Brakes for Dodge Dakota
Can I drive my dodge dakota while im smelling burning brake fluids after brake job ?
Recently replaced rear brakes no apparent leaks is its safe to drive
  • 62 Answers
Is it brake fluid or over heating brakes?
It is possible that the brakes are adjusted too tight. Check for leaks as well. Have someone press and hold the brake pedal down while you looks for any drips.
Posted on Apr 06, 2014
    New Friend:
    Problem Solver:
  • 12 Answers
Did you clean the oil off the rotors and drums? also it may not be from the brakes but the master cylinder which i believe has part of the exhaust running underneath it pending if it's a v6 or not. if it is the master cylinder or lines near it may be leaking and dripping onto the hot exhaust thus the burning smell.
Posted on Nov 14, 2013
Rear drums smell like something is burning and are hot.
remove the drum and inspect you job. small shoe on front big shoe on back.brake lube on the backing plate.lose the adjuster and inspect,lube the adjuster, give more free play on your parking brake cable 3 click is the normal before lock the wheel. Inspect the master cylinder for overfeel, remove any fluid over the max level. inspect the fluid for contamination(burn smell or oily)flush the system. lift the Jeep and pump on the brakes,if the wheel is locking open the bleeder screw.if brake fluid is under pressure,replace the hoses.
good luck
Oct 24, 2014 | 1999 Jeep Cherokee 4WD
How to adjust rear brakes on dodge dakota sport,2000?
if you have never replaced the factory rubber brake hoses , now is a good time to replace them
you probably have a small hydraulic fluid leak in 1 of the rear brake cylinders
May 04, 2014 | 2000 Dodge Dakota - All Dakota models -...
2002 Dodge Grand Caravan leaking fluid
Since the Caravan is front wheel drive, there would be no transmission lines running to the rear of the vehicle. This reduces the possibilities to either a fuel leak, or a brake line. If you smell the fluid you should be able to tell immediately if it were gasoline. This would be a dangerous thing. Fuel leaks must be isolated and repaired quickly to avoid risk of fire. If it were brake fluid, and the leak were stead, you should, if you inspect the brake master cylinder reservoir, a lower level of fluid than normal, possibly even a total loss of fluid in the rear chamber. If so, then the brake line to the rear has probably ruptured from age/corrosion. It must be repaired or replaced.
Dec 07, 2013 | 2002 Dodge Grand Caravan
Rear wheels lock up on my dodge dakota
What year Dakota? Drum Brakes?
Lock up when?
If you use the parking brake,then the cables
have to be replaced because of rust.
With proper brake maintenance once a year, there is no
reason to say they lock up while driving
Feb 02, 2013 | Cars & Trucks
How can tell if brake caliber is sticking?
Park on level. Put transmission in neutral, emergency brake on, and block or chock a rear tire, so car won't move when you raise that front tire with a jack. Use a jackstand or big block to stabilize car (safety first!), when it's raised.
Now try to spin tire. If caliper is stuck tire will be very difficult to rotate.
Found the problem yet? Take the wheel off and investigate further. The burning smell has to come from somewhere. Any sign of brake fluid leaking?
Have somone pump the brake while you watch the caliper. You should see a very slight movement when caliper pushes pads against the brake rotor. When brake is held, the rotor should not turn. If it does, the caliper is stuck inside the bore, and will have to come off for rebuild or replacement.
Good luck.
Hope you find the problem,
Nov 25, 2011 | 1997 Dodge Dakota
I HAVE FLUID LEAKING FROM THE REAR PASSAGER WHEEL HOW CAN I FINE WHERE IT IS COMING FROM.
Hi, it is likely your brake wheel cylinder has failed. You would need to jack up the van and remove the wheel and drum to verify. See photo below and let me know if you would like instructions for replacing the cylinder. The part is about $12 at Autozone.
Mar 10, 2011 | 2003 Dodge Caravan
Replaced front brake lines and now I have to bleed the brakes on my 1999 dakota truck
go in this order-
-make sure the fluid resivoir is full and the cap on
-crack both front bleeders loose and allow them to "gravity bleed"
-once you see fluid constantly dripping out of the bleeder close them
-do the same with the rear
-after you have gravity bled the brakes grab a partner and have them pump the brake 4 to 5 times holding the pedal down on the fifth time
have them say "holding" while you crack the right rear bleeder-once the pedal hits the floor they should say "floor" and hold it there while you tighten the bleeder. repeat until you see nothing but fluid squirt out.
repeat this whole process in this order
right rear
left rear
right front
left front
make sure to continually check the brake fluid level so it doesnt get too low
this should work unless the master cylinder leaked dry from replacing the lines-if this happened you will most likely have to bleed or even replace the master cylinder
Aug 12, 2010 | 1999 Dodge Dakota
T brakes after driving on a donut pare
I believe driving on the donut spare has nothing to do with the problem-it isn't all wheel drive option is it? You say you added brake fluid, how low was the level? If it is losing fluid, you might have a rusted brake line that is leaking. Any evidence of a leak under the van? It's possible the master brake cylinder is bad, but this seems to be a sudden start of the problem. Did the tire blow out or did you go out to find it flat in the morning? I believe this is a leaking brake line issue. It is possible that if the tire blew out while driving, or you hit something (like debris) in the road, it may have damaged a brake line. As I mentioned earlier, it could just be a rusted leaking brake line. If brake fluid leaked on the exhaust or any hot components, it would give off a 'chemical' smell ( or even have an odor if it just leaked out) Let me know what you find.
Nov 30, 2009 | 1995 Dodge Caravan
Bleeding brakes
always bleed front driver side first, front right,left back
right back.
make sure you always have oil in the master
Apr 08, 2009 | 1993 Dodge Dakota
Brakes for Dodge Dakota Logo
82 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
