Ge washing machine spins out sometimes and them don't have any ideas
    New Friend:
  • 25 Answers
Spins out? from wall? Might not be balanced. Tilt machine forward 2-3 inches to get the back feet off the ground, and let it back, They have self leveling legs. Not sure what the question is.
Posted on Dec 09, 2012
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
rickzilla
  • 706 Answers
SOURCE: Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Dec 06, 2008
  • 1028 Answers
SOURCE: Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Posted on Dec 18, 2008
  • 3230 Answers
SOURCE: G.E. washing machine will not drain completely
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
good luck.....
Posted on Mar 28, 2009
Washing machine don't makes the spin dryer at the end of washing cycle
This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 21, 2013 | Bosch Washing Machines
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
I have a GE top load washer Model WJRR417G1WW did not spin out after rinse cycle.. any idea? Jen
heatman101
Apr 14, 2011 | GE Washing Machines
GE adora WHDRE526EWW when started it begins to fill then stops filling and have to restart sometimes three to four times help!!!.
I wish I had a solution, I have the same issue. My WHDRE526EWW Top Load washer stops intermittently sometimes while filling up, sometimes while rinsing, sometimes while washing and sometimes while spinning. I just have to guess when it's going to stop and check on each load frequently to restart it when it stops. Sometimes I can't even get it to start spinning again and I will have to unplug it and plug it back in and then it will spin. Hope someone can help!
Jan 05, 2010 | General Electric WHDRE526EWW Top Load...
My GE washing machine does not spin the water completely out of clothes. Garments come out very soggy and have to be wrung out by hand before putting them in the dryer. Any ideas?
My washer was pausing during the rinse cycle, sometimes leaving the clothes very wet as well. I pulled out the filter underneath the lower panel, it was packed with coins, etc. Has been running fine (draining) ever since. Hope this helps...
Oct 01, 2009 | GE WSXH208A Front Load Washer
GE washing machine leaks at bottom
If this machine has a place to put pour fabric softener in that's sits under the lid on the cabinet? If so, the hose that allows the softener drain into the tub is either leaking or is disconnected.
Please rate this solution if helpful
Aug 20, 2009 | GE Washing Machines
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Ge washer # WBVH6240FWW
We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
Aug 15, 2008 | GE Profile Prodigy WPSE4200A
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
