Question about Acer X193W LCD Monitor
Wont turn on at all
I just got an Acer X193w+ and i took it out of the box and set it up. but when I tried to turn it on, it felt like the button was stuck. it wont move at all, and I cant turn on my monitor. when I plug in the power cable, no lights come on or anything. what do i do? is it faulty?
  • claymore2106 Jan 13, 2009
    wait i found it. it clicks in the back, while every other one clicks in the front. human error.
  • Thomas F. Schneider May 11, 2010
    Sounds like a bad switch. Why mess with it? Send it back.
  • 3 Answers
Alot of times if it doesnot receive a signal from the computer, no lightes will come on. Try the svga connection and make sure it is connected tight. If you get nothing and you video card has a digital connect, try using the digital connector
Posted on Apr 28, 2009
  • 2,692 Answers
Fix Ya?
Posted on Jan 13, 2009
What will show on the screen if you connect lcd acer x193w only electricity? (Without the PC you plug inserted in lcd acer x193w.) I show my "Acer" and turns off, then starts again and goes off...
Normally when you don't plug a monitor into your computer but just into the wall socket then you should get a No Signal message displayed. If the monitor is behaving erratically then it's not a good sign. Try plugging the monitor into your PC as well and see if it still keeps switching on and off.
Apr 17, 2011 | Acer X193W LCD Monitor
How do you change the contrasting on the acer monitor x193W
Check for hidden buttons around the ridge and on the back if none are found you will need the software from acer to manage the display settings
Jul 21, 2010 | Acer X193W LCD Monitor
My Acer X193W monitor has discoloration, a neon green on the screen wherever the darker colors would have been displayed. Is it dying or just needs adjustment? (Changing the settings to different...
Its a last resort make sure no magnetic devices such as speakers are near it and look for a reset function...if you can get into settings try turning it off and then turn it on and try again.
Jun 15, 2010 | Acer X193W LCD Monitor
Can't change the resolution of ACER X193W. All attempts to change the resolution come up with "... not supported". What is the problem?
check in your computer graphic drivers are installed correctly.
If installed then when you power up the computer press F8 key then enter in enable vga mode.Set screen resolution to 1024*768 then apply and ok.
You can set screen resolution in control panel dispaly property.
Jul 14, 2009 | Acer X193W LCD Monitor
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:'s%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
How to adjust intensity of Acer X193W LCD monitor manually
if you go into the screens menu, there will be a button for contrast and brightness.  When you have the one you want selected, press munu again and that will bring up the dialog to change the percentages.
Mar 06, 2009 | Acer X193W LCD Monitor
Acer's x193w killing my eyes..please help
First off, LCD monitors have what is called a 'native resolution' and that is why it is recommended to be at 1440 x 900. That is the resolution they work best at. My first suggestion is to try to move the monitor closer to you. If that is not possible, try right-clicking on your desktop, click on the Properties tab (That is where you change the resolution. I am doing this for a Windows XP machine - if you are running Vista please let me know and I will try to walk you through it there). Click on the "Advanced" button and in the "General" tab, there should be a "DPI Setting" drop down box. There is usually 96 DPI and 120 DPI. Try 120 DPI and see if that helps.
Second, try using your monitor's menu settings to help the color settings. On your monitor there is a "Menu" button of some sort. Press that and select "Acer eColor Management" and try "Text Mode" to see if that is easier on your eyes. You can also manually adjust the screen and lower the strength of the red color by picking "User" instead of "Acer eColor Management" and selecting the icon that looks like a pyramid of 3 dots. Try adjusting the Red slider and see if that helps.
Jan 02, 2009 | Acer X193W LCD Monitor
Acer Monitor: X193W Well, nothing wrong with it... it is turning it on. When I press the button to turn it on, it don't work. Would I have to get another monitor or try find another power cord? Should I...
first you need to try other power cord from other monitor and then to try your monitor to other computer if this dont work then here it is a problem with the supply and could fix only in service .
Dec 10, 2008 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
