Question about Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
How do you remove the heap filter - Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
  • Dyson Master
  • 18,411 Answers
How should I clean the ribbed filter? Can I rinse it under a tap?
If it is a heap filter just replace it. If it is a foam type clean it an let it dry. Then put back in unit. Heap filters are like a paper with a wax on them an are very stiff. Just get a new one they last for years.
Jan 27, 2016 | Vacuums
How to replace heap filter?
There are information videos on YouTube . com showing step by step replacment
Aug 07, 2014 | Dyson Dc-18 "slim" Upright Model...
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
How do I change the belt on my bissell 6594c vacuum?
If yours looks like this one: http://www.bissell.com/ProductDetail.aspx?id=9778
lay the vacuum upside down, remove the screws that hold the plate over the brush roll, or some models just have tabs. Remove the plate and then take the brush roll out of the body. Place the new belt on the metal motor shaft and loop the brush roll pulley thru. Pull forward and place the roller into the housing, turn by hand a few rotations to make sure the belt is tracking straight. Replace the bottom plate and secure with either screws or click tabs in place. Flip vacuum over and it's ready for use. Make sure to keep your filters as clean as possible otherwise you will lose suction. You can wash any foam filters in the sink, but let them completely dry before re installing them; do not wash pleated heap filters, see owners manual for care and replacement.
Nov 03, 2013 | Vacuums
Need filter everstar vc 9550
I'm needing a filter for my everstar 3 stage heap vacuum model bck 9550, do u know where I can purchase one?
Oct 27, 2013 | Eureka 431A Optima Bagless Upright Vacuum
Sensor light stays red no matter how long I vacuum. I think the sensor light is broken.
I think you have a clog and/or a dirty filter.
Check all hoses - dont just look at them ... disconnect them - run something through them - check completely. I pick up dozens of discarded machines from the trash heap - more than 90% have clogged hoses and nothing else wrong with them.
I hope this helps
a
Sep 26, 2009 | Kenmore Vacuums
I am trying to take my philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the...
Generic problem for all Vacuums
I am trying to take
I am trying to take my Philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the life of me find how the wheel end comes apart. Any tips?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe the part you are taking about is the fan and the fans generally are installed by a reverse thread and screws off counter clock wise. Once you removed the fan or the wheel you can use a blower and blow the motor clean, remove the carbon brushes and use a pipe cleaner to clean out the carbon brush holders and then re-install. Also free to contact your local vacuum cleaner dealer in your area or in the yellow pages under vacuums.
Apr 22, 2008 | Vacuums
Dyson DC18 all floors Bagless Upright Cyclonic Vacuum Logo
191 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
