Question about Spidem Trevi Digital Coffee Maker, Espresso Machine
Can you please explain to me the procedure for decalcifying
I need to know what to press in order to start decalcifying i already have the product
Http://www.partsguru.com/FixingaVienna.html pretty good site for info. and manuals.
Posted on Apr 01, 2009
What does error 1106 indicate?
First please find your PC network settings: Step 1/ : How to check your PC network settings: Using the PC that is already networked to the same network router, please carry out the following procedure. On the PC desktop click Start then click Run now type in cmd and click OK (with Vista/ Windows 7, type Run in the search field located at the bottom left of the desktop and then open Run and type cmd) At the command prompt type ipconfig then press enter/return on the keyboard. The computer will now display setting figures which will look like but not the same as the following examples below. IP Address: 192.168.01 Subnet Mask: 255.255.255.0 Internet Gateway: 192.168.11 Now that the PC network setting figures have been located, the Sony networked product must also be checked to see if the setting figures are the same as those found on your PC. Step 2/ : How to check the Sony product network settings: Using the Remote control press Home/Menu Go to Settings Go to Network press OK Go to Network Set-up press OK Go to View Network Status press OK All the figures shown on the Sony product should match with those on your PC apart from the last 3x figures of the IP Address. The last 3x figures of the IP address sequentially differ due to each networked product having a slightly different IP address, this is normal. Depending on the outcome please see either A/ or B/ below. A/ DO MATCH : PC and Sony product setting figures DO MATCH If the PC and Sony networked product setting figures match but there are still networking issues please do not go to STEP 3 but contact Sony support. Details are listed below and titled Sony Support. B/ DO NOT MATCH : PC and Sony product setting figures DO NOT MATCH If any of the setting figures differ (apart from the IP address as explained above) then that would indicate that there was a problem during the network set up. To resolve this, both the Sony product and router will need to be Reset and the Network set up process started again. Please continue to STEP 3. Step 3/ : How to reset the Sony product and router: Reset the Sony product Using the Remote control press Home/Menu Go to Settings Go to System Settings and press OK Go to General Set-up and press OK Go to Factory Settings and press OK Restore Factory Settings and press YES Once this has been completed turn the TV off at the mains and then switch back on again. Reset the router Usually, press any reset button on the router, or switch off and on at the mains and wait for the lights on the router to settle and become constant. If it is un-clear on how to reset the router, please contact your Internet provider or router manufacturer. Once both products have been reset try the network set up again. Sony Support If there are still networking problems after checking through the procedure above, please contact Sony support with all of the information required as listed below, please call 0844 8466 555 Mon-Fri (9am to 5pm) Sony support will require the following information to help identify any problems that you may have with your network connection. · A full description of the networking problem · IP Address, Subnet Mask, Default Gateway (completed using Auto configure only) · Router make and model · Type of security used WEP or WPA · Wired (cable or Home Plug) or Wireless connection. · What actions have been carried out to help resolve the issue already
Read more: How do u fix error 1106 connecting broadband to sony bravia kdl 32ex520 (no router)? - I have a broadband that i use for my laptop. when i connect to my sony bravia i shows error 1106 and i dont use router to set up anything with router. I connected as a wired connection and cable and ip address is ok but internet connect failed and shows error 1106. Can you please help me out on this :: Ask Me Fast at http://www.askmefast.com/How_do_u_fix_error_1106_connecting_broadband_to_sony_bravia_kdl_32ex520_no_router-qna1013157.html
Oct 31, 2015 | Office Equipment & Supplies
Tip
How to reset the lamp timer on Sony Projection TVs.
If you have replaced the lamp in your Sony projection TV you must reset the lamp timer to get rid of the message saying that your lamp needs to be replaced. Let's face it, you know you already accomplished replacing the lamp but the TV isn't smart enough to know that. I will explain in detail how to accomplish the reset procedure.
Resetting the lamp timer is a complicated procedure but you should be able to do it if you have plenty of patience and know how to follow instructions. Read the procedure over first several times before trying to do it and locate all the buttons on the remote. You may want to try the procedure on the remote to make sure that you have the sequence memorized.
By the way the lamp life is figured to be from 5000 to 8000 hours. That is not much time if the TV is being used for more than 8 hours per day. If you do the math and watch your TV for 8 hours per day (not uncommon) the lamp will need replaced in 3 to 5 years. So be ready to do this procedure again in the very near future.
Here is the procedure.
All commands should be done using the factory remote:
1) enter the service mode by pressing display, 5, volume +, Power on
2) press JUMP 3 times
3) to display the time press channel 2, 9 times
4) to reset lamp timer press channel 3, MUTE, Enter
5) to check the time press channel 1, 7 times
6) when complete turn set off to exit.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 30, 2010 | Televison & Video
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
On the screen it is written decalcifying.How do I fix this?
This is a pretty sophisticated coffee maker.. the manual goes into great detail about set up for entering water hardness and descaling messages. There is a discussion about the decalcifying procedure, but none the mentions a decalcifying message.
You should re-read the manual and possibly re-enter the programming again. The manual is available for free, here. Pay particular attention to sections 15, 16a, 20c and 22. These sections are only a paragraph long, but will help explain the filters, decalcify procedure and decalcification tablets.
Please rate this reply - thanks!
Dec 03, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Windows donot accept my key product
Use the Telephone Activation procedures. The product key is already in use - by YOU! telephone activation should work - if the automated responder doesn't accept the key, then call back, and do not respond when asked which service you want - that should force an operator to answer, and you can explain it to them, and resolve the situation. wish you the best of luck and please vote
Nov 29, 2010 | Microsoft Windows Vista Home Basic for PC
I am having trouble starting the decalcify program, even though the light blinks "ready/decalcify"
Had the same problem, i noticedt that there is a procedure to run decalcify anytime in the instructions book.
Turn off the machine, press Rinse button until it says Empty Tray then go go Step 2 in the instructions.
Nov 27, 2009 | Jura Capresso Impressa F7 Espresso Machine
Machine is displaying "Decalcify" message; I do not know how to do this
I believe the machine is telling you that it has already ran through the decalcification proceedure, and that it is ready for use.
May 09, 2009 | Computers & Internet
Decalcify
im not a saeco folks but i buy those machine on ebay and repair them decalcify ready to used mean its ready for you to put descaling product in machine and you press on it will start the descaling sequence if you dont whant to descale i sujject you do it if not go in our menu and push botton untill you see descaling finish or done thanks pierre p.s taking about descaling my machine vienna told me this morning time to descale it comme about every 3 months let me now i know those machine good
Jan 10, 2009 | Saeco Incanto Classic Espresso Machine
Decalcify?
I had the same problem with a Saeco Royal Digital. I ran the decalcifying liquid through the machine with the automatic descaling program as per the instructions on the bottle and the DECALCIFY message stayed up.
I solved it by going to the menu and selecting "Signal Descal." and toggling it from No to Yes. I escaped back to the menu and git the usual "Select Product".
Hope this helps.
Nov 05, 2007 | Saeco Royal Professional Espresso Machine
What does Decalcify mean?
You can download the manual for free. Search for the manual.
If you want to decalcify, then you need to get decalcifying solution. The button with two circles is the decalcify mode. Press that, and the unit will go through it's automatic decalcify. There is a specific procedure to best decalcify superautomatic machines. Please search for that.
After this is done, the decalcify message will not appear. It is on a preset schedule, not an actual measurement of how much scale is in the machine.
Although you don't have to decalcify, it is recommended, especially if you live in an area with hard water.
May 14, 2007 | Gaggia Titanium Espresso Machine
Spidem Trevi Digital Coffee Maker, Espresso Machine Logo
548 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
