Question about Cell Phones
Bluetooth pairing trying to pair to car not sure where to find options. bluetooth on already
Ok what you need to do is put the other phone or whatever you are pairing with in discoverable mode which means you need to go to the settings and go to Bluetooth. kk this is a 12 year old too so yah hahahahahahahaha
Posted on Dec 09, 2012
  • 4 Answers
SOURCE: Pairing LG Shine and Bluetooth HS850 unsuccessful
UGH I had such a hard time with this, because it isn't clearly explained.
So here is a solution that should work (it worked for me!):
1. Go to Settings, Bluetooth, and Go to the "Paired Device" menu and leave it open.When it asks to turn BT on, you can do so.
2. This is the part here that screws everyone up. Take the headset and press and hold the multifunction button. KEEP IT HELD DOWN! The light should turn on and stay on. While you are holding it, open the microphone. The light should have been on while you were doing this and still be on. If it didn't stay on the whole way try again from when the mic is closed.
3. Remember the "paired device" menu? Select "New" and it will auto search for the headset.
4. It should be found quickly. The headset (that you should still be holding down but with mic open) will blink, then your phone will ask if you want to pair with Motorola HS850. Say ok, then it will ask for passcode 0000.
5. The headset will blink and the phone will say it was successful, and ask if you want it to be turned on. Say yes and make a test call. It should be fine from there.
Hope it helps!
Posted on Feb 25, 2008
SOURCE: pairing
I'm having the same problem with my verizon vx8600 phone. Only with a jabra bt350 (listed as compatible). It actually doesn't find anything at all, no phones, no headsets, no bluetooth enabled PC's. Not really sure what to do since I've discovered handsfree talking, I never want to go back
Posted on Jul 26, 2008
Bajanguru
  • 7752 Answers
SOURCE: blackberry pearl 8130 issue
restart the phone then try again or take the phone to a mobile store and ahve it check
Posted on Sep 19, 2008
  • 3 Answers
SOURCE: my blackberry bold does not recieve data via bluetooth
I think you read wrong praky, capt said already paired. The correct solution would be as follows:
1. Open the Media app.
2. Select a media type (e.g. Music)
3. Press Menu.
4. Select Receive Using Bluetooth.
5. Select Yes. (It will then ask you the location you want to save to but of course by default it will select the proper folder)
6. Select Save. (Transfer will begin
Posted on Mar 08, 2009
Bajanguru
  • 7752 Answers
SOURCE: Blackberry 8300 bluetooth pairing and sending but not recieving
enter 0000
Posted on Jan 30, 2010
Please someone help me. I've tried to connect to Bluetooth. I get so far along and then phone Bluetooth doesn't find the cars. Is there a fuse that might if gone? I did not get a manual with my car.
About 4,890,000 results (0.54 seconds) Search Results
    How to Fix Bluetooth Pairing Problems - Techlicious
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/
    Dec 29, 2015 - Determine which pairing process your device employs. ... Let's say you want to pair your phone with your car's infotainment system so you ..... If your tabletdoesn't come with built-in Bluetooth (and it looks like most, if not all, ...
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing...-/CP2/
    Dec 29, 2015 - Let's say you want to pair your phone with your car's infotainment system so you can .... i factory reset my tablet and now it wont find my bluetoothspeaker to pair! .... It doesn't look like you can revert to the previous firmware ...
    Bluetooth FAQ for Windows Phone ' Windows Phone How ...
    www.windowsphone.com/en-us/how-to/.../bluetooth-faq
    Windows PhoneRead the Bluetooth FAQ for Windows Phone and get answers to common ... You can pair your phone with a variety of devices that use Bluetooth, such as the hands-free system in your car, headsets, speakers, ... Where can I find it? .... ?My phone doesn't reconnect to the Bluetooth hands-free system when I get in my car.
    iPhone 6 not connecting to car Bluetooth ' Apple Support Commu
Jan 27, 2016 | 2006 Ford Focus 2.0
Trying to bluetooth pair a Cowan s9 to a jbl charge
Bluetooth connection should be in Settings menu. From there, choose Bluetooth then turn on the Bluetooth transmitter by touching the second option from the left at the bottom of the screen (Bluetooth symbol). After that, press the locate Bluetooth button (the leftmost choice). Make sure your headset is turned on. The player should list your headset once it finds it. There might be a button on headset that needs to be pressed in order to pair it with a device. Once the headset is located it should ask you for the pairing code (usually 0000). If the code is different for your headset, press the rightmost button at the bottom of the screen and enter the code.
Nov 07, 2013 | JBL Charge Portable Wireless Bluetooth...
How do I use the loud speaker on a Blackberry pearl?
Hi there
Although the Blackberry pearl does not come with a speakerphone, you can still set up this function by using a Bluetooth device.
HERE IS WHAT YOU SHOULD DO
Power on your Blackberry using the On/Off button in the lower right-hand corner of the device
Turn on Bluetooth
Find the Bluetooth option. In the main menu, select "device options."
Enable Bluetooth radio. Click on the trackwheel to scroll down until you see the option "Enable Bluetooth". Select this function (click the trackwheel) to turn on Bluetooth compatibility. If you have completed this step correctly, you will now see a "Bluetooth icon" on your Blackberry screen. If you want, you can later turn off Bluetooth by repeating Steps 1 to 3 and then selecting "disable Bluetooth".
Pair your Blackberry with a Bluetooth speakerphone
Power on your Bluetooth speakerphone device using its On/Off switch or button.
Find the Bluetooth option in the main menu by again selecting "device options" and then using the trackwheel to scroll down until you see Bluetooth. Select this by clicking the trackwheel.
Add your Bluetooth device. Click on the trackwheel to scroll down until you see "Add Device." Then click on the trackwheel to select this function.
Enter the name and passkey of your Bluetooth device. When prompted, scroll down with the track wheel until you see the name of your Bluetooth device. Your Blackberry automatically detect your Bluetooth speakerphone if it is within 10 meters. If it does not, enter the name of the device, then type in the passkey provided by the manufacturer of the speakerphone.
Enter the passkey on your Bluetooth speakerphone. Your Blackberry and Bluetooth speakerphone can now communicate with one another.
To use the speaker during a call all you need to do is;
Dial a number and hit the send key. Make sure that your Bluetooth speakerphone is on, and that you have already set your Blackberry to "Enable Bluetooth." If you see the "Bluetooth icon" you have already done this step.
Activate your Bluetooth device. When the call has connected, click on the trackwheel until you see the option "Bluetooth Device". Then click on the trackwheel to activate the Bluetooth function. Your Blackberry will now route your call to the Bluetooth Speakerphone.
Turn on the speakerphone. Depending on which Bluetooth Speakerphone you have purchased, you may need to click on the "speakerphone" button to enable this function. Once the speakerphone is on, you may continue with your phone call.
Sep 19, 2010 | Cell Phones
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
Blackberry won't pair with sony bluetooth
Can you try these steps even if you have already failed - so it is clear exactly where your problem lies and how your blackberry is behaving.
Turn on your Sony device and activate the bluetooth feature, set it to pair or search for a device (if this is a headset, it will search automatically, once it is turned on)
On your Blackberry choose the bluetooth option and enable
At your next prompt, when asked ensure your bluetooth device is in pair mode - Say Yes
It will go through a searching for devices screen
Here you will find a list of bluetooth devices in your range that can be paired - (these devices should include your sony)
If at this point you get a message stating no new devices found - Say Ok
Do you see a list of previously paired devices which includes your Sony?!
Let me know how you get on with the above, and what if any error message you receive.
May 15, 2009 | AT&T Blackberry Curve 8300 Smartphone
Where is pairing on the k750i
Hi
If you go into S/E K750i menu and into settings, then scroll once to the left and you should see Bluetooth menu (at top?). Enter Bluetooth menu and firstly make sure your phone is set to discoverable in 'Visibilty'? Secondly if you go into 'My Devices' you should have option to 'Add Device' selecting this will scan a 10 meter radius for other Bluetooth devices to talk to.
With most B/Tooth handsfree you will need to set it into pairing mode (this stops anyone logging onto your handsfree) Pairing only needs to be done once, unless you suffer connectivity problems at any time, and is the first thing to try to solve the problem.
I believe I have already sent you a link to the instruction book for the Parrot system you have and that should tell you how to set it into Pairing Mode. Hope that helps? Good luck.
Apr 24, 2009 | Ericsson Lands Phones
Pairing an "universal" bluetooth to the samsung behold
Do you still have the user manuals for both the phone and the IHF1000? Start by reading the bluetooth pairing sections in both manuals and trying what is listed. If you have already done this, then please detail where you are having difficulty in the pairing process.
Apr 20, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Blueant Supertooth Light Bluetooth Speaker...
How can i reactivate my blueant blue tooth on my motorola ic902?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 15, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
