Question about HP Pavilion zd8000 Notebook
19 " HP zd8000
Monitor show very very lite lines vertically. let me know what i should do.
I had the same issue, it started with one at first then progressed to 200+ lines of all the primary LED colours. I tried using the VGA out on an external monitor but noticed light static on dark areas of the screen. Another post mentions a uniform red square pattern. I got this too, and ripped the whole thing apart to find the heat sink cooling fins clogged with dust and the video chips discoloured. Sorry to tell you but by the time this happens it is too late, the on board video card has cooked itself to death. If you haven't experienced it yet, eventually the video card will crash your system and you will have no choice but to disable it and use a USB external video card and monitor.
Posted on Jan 18, 2009
Vertical lines in hp zd8000
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical line. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Sep 26, 2010 | HP Pavilion zd8000 Notebook
I have virtical lines on lap top
Once you start to get vertical lines on your LCD screen, it's usually time for a new screen. I would check first by running an external monitor just to be sure it's not the video card.
May 19, 2010 | HP Pavilion zd8000 Notebook
Vertical lines have appeared on my hp pavilion zd8000 can u tell me how to fix it please?
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mptherboard. If the problem appears on both screens, external and laptop, most probably the video card/motherboard is defective.
Have it checked/repaired by a professional.
Oct 08, 2009 | HP Pavilion zd8000 Notebook
Vertical multicolored lines appear. Sometimes there are couple of vertical white stips and vertical lines
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mainboard. Have it checked by a professional.
Oct 05, 2009 | HP Pavilion zd8000 Notebook
White vertical line on monitor screen
The vertical line is because the screen is going, it needs to be replaced fix the problem. Try searching on Ebay if your laptop isn't under warranty.
Aug 30, 2009 | HP Pavilion zd8000 Notebook
Same problem with my zd8000 HP Pavilion laptop
what has happened with your notebook is a simple wear factor. on the LCD screen there are ribbon cables witch join the main PCB controller head to the LCD laminated portion (what you see) have begun to wear. i have just recently replaced a screen because of the same issue. try gently flexing the the screen and see if the lines dissappear. next open the screen up, and check the cable running to the back of the screen take care as to not damage anything.
Aug 12, 2009 | HP Pavilion zd8000 Notebook
Hp pavillion zd8000 monitor has 37 vertical lines
Interesting that you counted them!
If you haven't tried to reinstall the video drivers, do that.
If that doesn't work, hook up an external monitor to see if the display is OK on that.
If it is, then your LCD screen has a problem and will need to be replaced.
Jun 29, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
