Question about Samsung R519-53S Notebook
Keyboard on Laptop QX BA69-00912A is not producing the letters / numbers pressed
  • Samsung Master
  • 32,281 Answers
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Posted on Dec 09, 2012
3 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: Keyboard problem
Press the FN (Function)key and the NmLk (Number lock) key at the same time.
Posted on May 08, 2009
  • 1570 Answers
SOURCE: some letter of the keyboard become numbers when i
Hi
Try to run the SYSTEM RESTORE in WINDOWS OPERATING SYSTEM. Go to START, CHOOSE ACCESSORIES, CHOOSE SYSTEM TOOLS, choose system restore AND CHOOSE RESTORE DATE the your keyboard works fine. If not, choose another restore dates.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on Jun 03, 2011
Keyboard incorrectly types a mixture of letters and numbers when certain keys are used.
There are a couple of things you could try:
1. Remove the keyboard following a service manual for your laptop, and reseat the ribbon cable underneath it.
2. If the problem still isn't solved, the keyboard should be replaced
Feb 03, 2013 | Computers & Internet
My letter keyboard is showing numbers and not letter..please help. (advent laptop)
Laptops do not have as many keys as a normal keyboard so often they include the numbers over letter keys.
So, by mistake you pressed a ctrl or alt or [A] key that simply switches the keys from letters to numbers.
A light or indication must be ON on your laptop indicating that it's Numbers or Letters ON.
Find the key that changes the function and restore the function to letters.
Aug 04, 2011 | Computers & Internet
My notebook has starting producing numbers instead of letters when I press certain keys - what is the problem?
Hi
you have enabled the numeric keyboard on your laptop
Try pressing the FN key (usually located at bottom left) and the F11 key.
If F11 key doesn't work you could try finding the F key with a mini keyboard icon on it.
Regards.
Jul 28, 2011 | Computers & Internet
Letters on keyboard are producing numbers instead of letters, letter k gives 2, letters u gives 4 etc
that is the keypad for a keyboard to get back those letter you will need to press the Fn button and on the top of the keyboard where there is a list of F button press the one that looks like a keyboard. if that doesnt work try Fn and num lock
Jul 07, 2011 | Computers & Internet
Some of the keys on my keyboard are producing wrong symbols not all of them mostly tge right hand side of the keyboard for example when i press the letter 'o' it produces /6 and the p produces -* how do i...
this means that your number lock is turned on.
there is a Fn key on the board. hold that and look for the number lock key and press it. each system is different so it will be either NumLk, NumLock, or a 1 with a lock symbol. Acer generally places this on a F key many times F7.
Jun 03, 2010 | Acer NSK8458AN Keyboard
Need instructions for keyboard toshiba satellite laptop , need to know what keys to push when using the numbers in the keyboard that are also letters
No need for the instruction manual. When your going to use the numbers that are inside of the letters, hold down the the FN key and then push the number that you want to be displayed. For example holding down the FN key and then pressing the L key produces the number 3 for me. Try your keys out and see what you get.
Jun 02, 2010 | Toshiba Satellite L45-S7409 Notebook PC
Numbers and letters will not show up when pressed....sometimes i hear a chime, sometimes not & touchpad problem also
First Off check that you DONT have NUM LOCK on !
On a laptop this would produce numbers instead of letters on some keys U,I,O,P,J,K,L.M
If that is not the cause and your operating system is windows based then check you have the correct drivers from the correct manufacturer (dell / compaq)
If you are all good up to here then it may just be a bad keyboard and may need to be replaced (usually not all that expensive on laptops) or you could plug a regular keyboard into an available USB port or keyboard port if it has one.
Aug 05, 2009 | Dell Computers & Internet
My laptop keyboard is typing different letters and numbers
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
Mar 18, 2009 | HP Hewlett Packard Pavilion DV9000Z 17"...
I press a letter a number comes up as the letter
You have your number lock on. Turn it off and you should be fine.
Jan 28, 2009 | IBM 08K4800 Keyboard for Thinkpad 560Z,...
Problem with keyboard or input of certain keys
hi.. is that a bi-lingual keyboard that you purchased? If so, what model? If that's a toshiba laptop w/ a bi-lingual keyboard, press the left (shift+ctrl) buttons for 10-15secs then release it. You should be able to bring back the normal function of your keyboard. If your having problems pressing the "n" key and it replaces it with a number on the screen when you type it, it's most likely that you enabled the "num lock" function of your keyboard, on Toshiba press FN+F11, on Dell FN+F11 also i think, it may differ on other models, sometimes FN+ Print Screen or Pause (above F11).
Hope this helps.
Oct 03, 2008 | Microsoft Windows XP Home Edition
Samsung R519-53S Notebook Logo
190 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
