Question about Sewing Machines
How to set the timing on a bernette 334D overlocker
Replaced gears, need to set the timing
2 Suggested Answers
SOURCE: 334d Bernette Overlocker
went to local berinina shop and purchased booklet for 10.95 aus dollars
thankyou feona
Posted on Jun 15, 2009
How do I change the feed dog gear on a singer stylist 534
You'll need the service manual, because once the feed dogs are replaced, they need to be retimed. You can purchase and download the service manual for your machine here:
http://www.tandtrepair.com/StylistLine.html
Jan 27, 2016 | Singer Sewing Machines
How to check timing on pe180d embroidery machine
In case of adjusting sewing machine timing, there are twomain parts that you should follow.To adjust the hook needle timing on the rotary hook, first,remove the bobbin, bobbin carrier, and covers so you can see the movement ofthe hook. This may involve removing the needle plate for top loadingassemblies, or removing the hook cap from the front of the machine. Itoften requires the removal of the lower covers to reach the componentparts. Adjust as needed when doing sewing machine repair.Set the machine to a straight stitch at the defaultposition. Different models have different default positions including themost common far left and center positions. If no problems are perceivedin needle bar positioning, the default position will suffice. If thereare needle bar position issues, these need to be adjusted prior to adjustingthe timing. Follow proper sewing machine repair procedures.Rotate the hand wheel toward youuntil you see the needle reach its lowest position and begin its rise. Now lookfor the point of the hook as you continue rotating the hand wheel. Thepoint of the hook should strike inside the needle scarf above the needleby about 0.5mm. Sewing machine repair is vital for smooth operations.Check to see if the hook fails topick up the thread. Double check the needle bar positioning including thehook needle spacing. If these are appropriate and the point of the needlestill fails to pick up the loop thread, proceed to adjust the timing of thehook. Maintain regular sewing machine repair. Look for the lower drivemechanism. It may be a lower shaft with gears on either end. If this isthe case, look to the right end of the shaft for a gear with adjusting setscrews. Loosen and manually adjust the position of the hook. Tightly hold thehand wheel while turning the drive shaft to set the proper position. Retighten adjusting screws. Some models have timing beltsthat control the timing of the sewing machine. Look for a belt connectedon each with to drive gears. Look for work cogs on the belt. Inmost cases, you can reset the timing belt, without replacing it. If,however, the belt requires replacement you will need to do so. Loosen the drive mechanism on the right side to free the movement of the belt.Manually adjust the position of the hook to the needle and re-tighten set screws. This knowledge is vital for effective sewing machine repair.Once the timing has been reset,conduct thorough test sewing on the sewing machine to make sure everything isworking properly.Hope this will help you. Good Luck.
Oct 16, 2011 | Brother Disney PE-180D Computerized Sewing...
I need a schematic or photos of the under carriage of a Babylock BL1556. No repairman will fix mine. I have it disassembled at this time, and all of the new parts have arrived. Now I need see how it is...
the lower shaft (hook) gears should be no problems for any trained tech to replace and should not need any shafts to be removed. the pattern selector is usually sold as a module and factory set which is why you are getting the high quote as there is no guages or info on these settings. if you have the parts now have you gone back to the original repairman as i assume you have already paid for some of the work and this would be cheepest option for you. the last option is to send it to babylock as they have a repair techs who would be able to sort it out for you
aus sew tech
Apr 27, 2011 | Baby Lock BL1556
My riccar - model #808 - needs gears. is it possible to have these sent to me?
Yes. However, you wrote "gears" as plural. There is only one gear in that machine; the hook gear. The hook gear is inexpensive and easy to replace and retiming the hook is easy as well. There is another potential problem; the timing belt cogs. They are plastic and, over time, they split, causing the timing belt to jump off time constantly. The replacement kit (2 cogs, belt and idler pulley) is available but is extremely labor intensive and requires a high level of aptitude for mechanical repair.
If you need a hook gear, they are under $10 and can be shipped right to your door. 805-540-9294
Nov 01, 2010 | Riccar Sewing Machines
Re-time model Singer model 2010
For a close setting, the needle bar must raise about 1/8 inch when the hook point is behind the needle and the needle bar is in the middle of the needle opening on the needle plate.
You need to check the feed timing also after retiming the hook. The feed dog should start towards the rear as soon as the needle starts down.Good luck
sewman7
Mar 21, 2009 | Sewing Machines
Timing off
If the worm gear is located on the bottom of machine that has link connected to the bobbins and shuttle case.Before you engage the two gear the worm gear and the helical gear besure to adjust the position of the needle holder at the lowest dead center position and the bobbins and shuttles case was hooked up properly with the needle no thread inside also unplug the ac source before doing this.Assuming all at zero time order,you can freeely move the shuttle case with the bobbins at the center of the needle because there are no link connection when you disengage
the two gear.After setting up all at rest gradually engage the two gear and tight the allen screw no motion at all linkage when doing this otherwise changes of set up will occurs you can't get the perfect time order.If all are set, manually by hand rotate handwheel gradually if there obtruction on motion of all parts,they should be freely move on the right rotation.if OK put thread on bobbins winder set to bobbins and upper threat top spool.Set the proper tension on both lower and upper thread acquired to fabric,try too hook up the lower tension manually, If ok sew cotton fabric as trial manually only no power supply yet
until you acquired normal sewing If no problem persist.Apply power source and continue trial If problem on timing again judt repeat sequence assure the perfect alignment and setting on lower dead center.
Mar 12, 2009 | Sewing Machines
Replacing broken gears on Singer Touch & Sew Model 648
Remove the plastic faceplate from the front of the machine. There is a Singer logo button that you will have to pop out to release it, and then the lever nobs to get around to get it off. You can then access the allen screw on the top gear.
Remove all the set screws on both the top and bottom gears on the vertical shaft. Put them in a safe place.
The vertical shaft sits directly below the horizontal shaft, but there is some space between them and wiggle room to do the following. If the shaft does not slip down easily, use a small diameter rod or screwdriver to gently tap the vertical shaft downward until the top gear slips off the end. Remove the gear.
Mar 09, 2009 | Singer Sewing Machines
How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Mar 02, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
