Question about Sony Subwoofer Ss-wp23 From Ht-ss2300 Home Theater
Sony Subwoofer Ss-Wp23 replacement speaker - Sony Subwoofer Ss-wp23 From Ht-ss2300 Home Theater
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Can I connect a passive
No. Like most AVR's it only provides a Line Level output for an externally powered subwoofer. Get a separate amp for the sub.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Posted on Apr 17, 2011
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Feb 15, 2015 | Sony STR-DE597 Receiver
Need a woofer for sony ss-mf315
have you tried on amazon,ebay or you could go directly to sony's website and possibly order your 6.3 inch subwoofer
Dec 23, 2012 | Sony SS-MF315 Speaker
Want to open sony woofer ss ws102
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Sep 03, 2012 | Sony Subwoofer Ss-ws102
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
Can you tell me if a receiver Sony 7.1 works with speakers ss-mf515 and What happen because I use the higher volume and the speaker sound low?\r\nWhat kind of receiver works with the speakers I mencioned...
Since you don't name the receiver we have no idea of its audio power or compatibility with 'standard' 8-ohm speakers.
http://www.retrevo.com/support/Sony-SS-MF515-Speakers-manual/id/956ci160/t/2/
Any normal standardized NOT-all-in-one-hi-fi-in-a-box amplifier will work with these speakers.
Apr 05, 2011 | Sony SS-MF515 Speaker
Cant get sony sub woofer model no. ss-wg60 working on my sony receiver model no. str-de445
First, go into the "setup" mode of the receiver and go to speaker select, then toggle to sub, highlight and make sure it's "on" Then toggle to speaker volume and check the sub level. Maximum setting is "0". Make sure you are connected to the subwoofer output on the receiver as well. If you still have a problem, post a comment and I can help you some more.Hope this helps
Jun 20, 2009 | Sony STR-DE445 Receiver
What voltage required to power a sony subwoofer
Hey,
I just got one of these units, the SONY SS-WG990.
The RCA cable is direct conection to the speaker.
It requires external AMP.
The other cable is just for the system switch and LED.
If you just have this unit, all you need is an AMP to
feed it.
Apr 12, 2008 | Audio Players & Recorders
Sony Subwoofer Ss-wp23 From Ht-ss2300 Home Theater Logo
196 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
