Question about Canon imageRUNNER 400S Copier
Error 901 of canon imagerunner 400s - Canon imageRUNNER 400S Copier
SOURCE: Canon ImageRunner 400S - Clear RIP job
I think I can help but its been a long time . you need the clear the print jobs at the PC first then the print serveron the copier. turn the copier off and on, as it starts to warm up press the print button, now when it ask if you want to start setup press yes...scrool around till you see clear print server and say yes ....now reboot.
good luck
REP
Posted on Dec 23, 2007
  • 523 Answers
SOURCE: Making a Canon Imagerunner 400S a network printer
connect network cable from the machine to the switch or router, and give ur machine ip address compitable with ur network, then load the driver on ur computer and u will be fine.
Posted on Jul 06, 2009
  • 1126 Answers
SOURCE: Setting up department ID's on Canon ImageRunner 400s
Pages 4-16 thru 4-24 of the Reference and Copying Manual cover this topic. I have the User Guides downloaded...but can't provide a link to them.
Posted on Jul 08, 2009
  • 108 Answers
SOURCE: Where can I download a manual for a canon
Try this link for tons of Canon Manuals for instant download.
http://shop.ebay.com/i.html?_nkw=canon+service+manual+for+instant+download+&_cqr=true&_nkwusc=canon+service+manual+for+instant+downlod&_rdc=1
Posted on Dec 18, 2009
  • 114 Answers
SOURCE: Canon Imagerunner 3300G Error E000007-0000 what
E007 0000 An error in the rotation of the fixing film is detected. The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven. Main cause The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR. most of the time the fixing film is torn or slipping
Posted on Apr 20, 2010
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
Problem :
E604 Error Code. You followed all the troubleshooting steps in the service manual and still have an E604 code.
Solution :
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity.
Jul 13, 2012 | Canon imageRUNNER 400S Copier
Machine canon ir 400s error E051
hi sir my xerox machine IR 400 the error code e220
May 12, 2012 | Canon imageRUNNER 400S Copier
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
ImageRUNNER 400S Copier: Canon IR 330-400 Ps Ver 1.0 i keep getting the ...
E-100 is an error of the Laser Beam detect PCB. Either the laser unit is not working or the beam detect PCB is not detecting the beam. You can't see the beam so don't try. Since you are also getting a E-220 which is a Scan Lamp error. Most likely cause is a ribbon cable between the CCD unit and Image Processor PCB. You may need a tech to trouble shoot this problem
May 18, 2010 | Canon imageRUNNER 400S Copier
Error 301
that code is related to the scanning lamp
Mar 22, 2010 | Canon imageRUNNER 400S Copier
Can't access system settings on Canon imagerunner 400s
Turn off the main power switch, and
disconnect the power cord.
Remove the copyboard glass; then,
remove the screw, and detach the small
cover from the IP cover.
remove the remove all eprom dccon ram
& insert again & start the machine.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
Jul 06, 2009 | Canon imageRUNNER 400S Copier
I am having Cannon IR 400 .please help me in solving the problem of error E014 & some times is soing E 051,E 901,
Hello sir ; All the code you display are motor problem ,check the fuser unit motor first and then go to main motor, most likel is maint motor have problem, if that true replace it ,that is only way you can do.
Jun 13, 2009 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
old marine
old marine
