Question about Car Audio & Video
What's wrong with my speakers and amp? They sound like ****!!!!
I bought the amplifier install kit and followed it to a tee to hook up jensen xa-2100 200w amplifier to my Kenwood kdc x493 cd/mp3/usb player. The two pioneer tens {not in a box cause that wont fit under my backseat} sounded good in my friends truck but kinda sound weak in mine. The speakers are 6 or 7 yrs. old. I have no idea what the adjustment knobs on the amp do but i messed with them to get it as good as i could. WEAK!!! Any tips?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Your woofers are not going to sound very good unless they are in an enclosure (box). Very few woofers are designed as free air.
Posted on Dec 11, 2012
  • Jonathan L. Jaegerman
    Jonathan L. Jaegerman Dec 20, 2012
    this was the deal. Thanks. I have very little space. Is a band pass box a good idea?
  • kenw392
    kenw392 Dec 20, 2012
    Most decent car audio stores may have a box that is designed for your particular vehicle.
5 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Posted on Mar 16, 2007
hawkwatcher
  • 67 Answers
SOURCE: my kenwood kdc-mp235
I assume the amp is turning on (lighting up) No audio may be due to Burnt rca ground trace in your kenwood radio. If you have a ohm meter measure continuity from rca's ground terminal to radio chassis. Should be close to zero resistance. If there is no no continuity there are fusible traces on radios main board that burn open at times when to much current is flowing thru rca ground
Just a good possibility , haver seen this happedmany times.
If you need service manual let me know kstahl65@att.net
Posted on Jan 26, 2008
SOURCE: Kenwood KDC-322 volume cutting out
there buggers rewire the earth/ground
Posted on Jul 27, 2008
vetteman3002
  • 2299 Answers
SOURCE: my Kenwood KDC-X493 deck is flashing "Protect" ,
You can unplug the unit for 10 minutes. This will clear this.
Posted on Jan 19, 2011
Jensen ka4400 400w amp
Hello Brian,
I have done a search for the Jensen KA-4400 Amplifier manual, without any luck. Sorry.
However the following might be useful for you to continue the search:
(1) Jensen Customer Support: 800-732-6866
(2) Go to: http://caraudio.manualsonline.com/manuals/mfg/jensen/jensen_car_amplifier_product_list.html
(Be careful to copy ALL of the URL address).
Then click on "Ask the membership for help locating your Jensen Car Amplifier manual"at the bottom of the screen.
Then fill in the form.
Good luck.
Dec 13, 2011 | AMP Car Audio & Video
Similar prob.did the 12 steps on how to install amp(jensen4100,blue).red protec light comes on when starting car then goes out and is not followed up by the green protec light .green one never comes on....
If you are running a set or a single subwoofer with the jensen amp than you will want to hook up the rca cord to the subwoofer rca connection on the back of the stereo unit-the other rca outputs are there in the event that you want to run a 2 or 4 channel amp to power the speakers that are generally located in the doors or back deck-with that set up properly you would still be able to adjust the balance and the fader just as though you were powering the speakers with the deck. Pug the free ends of the RCA cord into the input rca receptacles of the amp- the stereo now will feed a signal to the amplifier that only contains bass - good luck
May 16, 2009 | Jensen LXA300 Car Audio Amplifier
220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
Apr 03, 2009 | Car Audio & Video
No audio output Jensen LXA300
well the "turn on" is just that - a relay inside the amplifier that allows the 12V Main to connect with the power supply on the inside of the amp.
hook up the remote turn on wire to a switched ignition source, and your amplifier will turn on.
If you are looking to TEST the amplifier - you can temporarily Jumper the remote terminal and the + terminal to get the amplifier ON - however when you instal it - you will want to put it on a switched power source so it goes on and off with the car.
If you need more help - im here.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 01, 2009 | Jensen LXA300 Car Audio Amplifier
How to connect mey speakers to the amp?
hi,i have 1000w 4 speekers but i have one amp.how do i connect to that?
Jun 24, 2008 | Jensen JHT525 System
A300HLX Amp + 600 Watt JL Audio Sub
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Apr 29, 2008 | Jensen A300HLX Car Audio Amplifier
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
No sound from speakers.
try with different speakers but disconnect all power (20min) cables first.
Aug 19, 2007 | Jensen XA2250 Car Audio Amplifier
Jensen XA4100
try using power directly from main to the remote terminal to see if headunit has a problem or the amp.please disconnect remote from head first.
Aug 18, 2007 | Jensen XA4100 Car Audio Amplifier
My amp keeps going into protective mode.
try to lower the SLA option on ur deck maybe the amp is pulling to much current from the battery try putting a battery with more AMPS
Jan 06, 2006 | Jensen LXA400 Car Audio Amplifier
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
