I have a Rowe ami R92 jukebox, when I turn it on I get error 37
    Problem Solver:
  • 22 Answers
Ok, If you get error 37 and the machine then operates normally. the error can be cleared.
If you have an active error 37 here is the cause.
Inner cam switch N.O. contact signal (Pin 5 of 6) should have been low (active) indicating that inner cam switch had closed; however, the signal stayed high (quiescent) longer than 30 seconds.
This error will cause phonograph to shut down until power is turned OFF and turned back ON.
Here is the solution(s)
1. possibility: Transfer motor LED is OFF
Probable causes: mech controlboard or wiring to motor defective
2. possibility: Transfer motor LED is ON
Probably causes: Central Control Computer or mech control boards; wiring from CCC to mech control; open circuit at inner cam switch N.O. contact; open circuit at inner cam switch Common.
I have personally had to replace the cam switches a few times. They are very poorly made.
Hope this was helpful.
Posted on Aug 29, 2015
Did you ever get an answer to you question on the error 37 for the Rowe R92 Jukebox
Peter
Rowe R-92 Jukebox
Posted on Oct 01, 2013
Selections already made on jukebox, how do I clear them
Hello stillwell42,
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Regards
Alan
Alan Hood
ami-man
UK
Mar 13, 2015 | Audio Players & Recorders
Rowe CD100A Jukebox CD carousel keeps turning.
if you got the service manual with it, it will tell you how to pull up the error codes and what to check.....I got lucky cause I just bought one and it had the manuals in it...mines is a rowe ami cd-100c. ....I just googled ur model and a pdf manual pop up for downloading. ...hope that helps!!!!
Mar 14, 2013 | Audio Players & Recorders
I have a 1979 rowe ami jukebox model R65 when i switch it on it plays one record then just spins the record magazine and wont select another record what parts do i need .
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
In the UK contact me
Alan Hood
ami-man
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
alan-hood@datex.co.uk
Mar 01, 2010 | Vintage Jukebox External Speakers Shelf...
I have a Rowe AMI 100CD jukebox. Its making a loud buzzing noise when I plug it in. Everything else works except the loud noise that I have to unplug it right sway. Do you think it is the red button fuse,...
Hello camillemario,
The problem sounds as if there is a fault on the amplifier.
Pull the 110 volt plug from the power supply that feeds the amplifier.
If the amp is at fault and you are in the USA I would contact Bruce Wentworth for a test/repair to your amplifier.
Regards
Alan Hood
ami-man
UK
Feb 21, 2010 | Wurlitzer Jukebox 1015 One More Time...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Mar 10, 2009 | Wurlitzer Jukebox CD Player
465 people viewed this question
 Grubhead
Grubhead
