SOURCE: bosch HMT8655GB, after being used no heat and cuts out at 22 secs
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
e6tuwe
SOURCE: Bosch HMB405 microwave will not heat
heatman101
gfshg
SOURCE: Bosch Model HMB8050(376 days old)
Hello &
Welcome to FixYa It seems that
the fuse is bad and needs replacement. You can get it done under warranty as
its just 1 day that the warranty expired, they can do it even when its 1yr 1
month old. Please get back to me if you have any other questions. Kevin
SOURCE: Bosch HMB 5050/01 Microwave -
I'm assuming this is a built in oven/microwave combination since you mentioned the oven works fine. On a stand alone microwave, we would reset it by unplugging and waiting at least 10 seconds for the microwave to reset itself.
Was the circuit breaker tripped when you reset it? When you reset the circuit breaker, did you wait long enough. Try turning the breaker off, then waiting a couple of minutes before turning it back on. Then give the microwave a try.
Another thing we run into with a built-in is that sometimes there is not enough air circulation. Check to see that the vents are clear and clean.
Good luck! Reply back if this does not solve the problem.
If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
SOURCE: I have microwave Bosch its shuting down few
Your inverter board is the problem, those cheap panasonic mags they use now short the diodes on the inverter board. Inverter technology is neat but does not work for very long. I order both the mag and inverter together on those everytime
