Washing machine Bosch Agency address in Malaysia
I need the main board for this machine with this serial number 05463 - n 10 se09 03 Dec 20:50 epw59159 04
  • f_amozegar
    f_amozegar Dec 10, 2012
    The model is WFO 2062
SOURCE: Problems with washing machine cycles
does it heat up? if not the element has gone and needs replacing. try it out on a cold 30 wash to see if it goes through if so element probs.
Posted on Jun 01, 2007
IB4G2008
  • 3587 Answers
SOURCE: Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Posted on Feb 27, 2008
SOURCE: BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Posted on May 23, 2008
  • 64 Answers
SOURCE: bosch washing machine will not fill, spin,
If it won't fill it may not spin or drain unless the water level switch is bypassed. I would check the water valve & the water level switch and tube from level switch to tub must be air tight no holes.
The water level switch must kick in to agitate. I'm not sure on Bosch but some work like this..
Posted on Jun 10, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
What type of bearings do I need to repair a Bosch Classixx 6 washing machine Serial No. e-nr wae24363gb/05 fd8901 602075
all bearings have their identification numbers etched on the sides of the bearings
you will have to get the old bearings out and take them to a bearing shop to get the same bearings
or you could simply buy the bearings from a bosch service agent or parts shop
Dec 28, 2016 | Bosch Washing Machines
Bosch 500 series new dryer has locked up. Key showing on panel, door opens, but you press every button and get the same beep.
Hi dear.
Regarding your information, I would say Child lock has been activated. I do not know what model or serial number of your dryer but you need to refer your machine's user manual or contact Bosch for deactivate child lock. I hope that helps. Thanks.
Jan 22, 2016 | Bosch Vision 500 Series Front-Load Washing...
Need a manual for bosch front loader wkm41
http://laundry.manualsonline.com/manuals/mfg/bosch/800_series.html . That should be the manual for the bosch wkm41. If not get back to me and i'll take another look. Also the bosch website has manuals searched by serial number if you get too stuck.
Dec 28, 2014 | Bosch Washing Machines
Bosch exxcel 8 washing machine, display dead when you turn on and door locked, fuse is fine..
probably the main board, you need a proper machine expert these day to reset the codes, designed so only they can do it.
Aug 17, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
Can you give any suggestions for a good advertising or branding agency in Malaysia?
There are various planets and channels are available for brand advertisement and publications. For any of new business there it is quite difficult for that person to exist or get stand against that thing. Particularly branding agencies are lots of in Malaysia but some of them are having good business there but as much as our agency there. Some branding agencies are known as Bates Malaysia, Ogilvy & Mather Malaysia, Naga DDB exactly having max success there for making any kind of brand most popular there.
http://www.laughingsamurai.com/services/
Oct 19, 2012 | Dream Rights Agency Android Apps
My bosch washing machine Maxx classic wont turn on
Please check the main power from the power outlet the mains plug to the controller unit. If there is power then check within for the fuse, if fuse is intact then check for burnt items, if so the board could be damaged and needs a replacement. In most cases if the fuse has blown it is possible that the board has failed and so changing the damaged component could be difficult as the board is immersed in epoxy.
Sep 12, 2012 | Bosch Washing Machines
There is no power going through my Bosch 1200 washing machine. I have changed the fuse but nothing. The powe supply is fine. I have moved on Saturday and the machine was working fine in the morning
In such cases what is needed is to remove the power plug and using a multimeter you must check the continuity of the power to the main controller board. If so connect and check the mains voltage to the board. If the boarrd does not respond you need to remove and replace unless you are an expert to check for component level failure.
click this link for tips : Control board
Jun 26, 2012 | Bosch Washing Machines
Where is the Serial No on the Washing Machine?
the serial number is located in two places just inside the door on a sticker (most likely washed off though) or sometimes on the rear of the machine.if you cant find it you will need to call bosch and they can tell you if you where the original buyers they will have it on file
Dec 19, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Instruction Manual
I am sure there is one to download but did not found anything with google...
If search engines are no help, just ask some deep web specialists, e.g. http://manualfox.com - this is a manual search agency and if they don´t find it, it does not exist in the Internet.
Aug 29, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
