I need to reset my viore atb 150v converter box. I lost the manual...the screen stays on "installation guide" with the language choices... I cant afford cable and if i go another week without the Twilight Zone Im gonna snap!
SOURCE: converting crib to daybed
you should be able to go to that same website and just scroll down more towards the end. it should then tell you converting to a daybed.
Posted on Jun 30, 2008
SOURCE: lost manual for Nexxtech motion clock. Need to reset
Try and look up the instructions on the internet. That may help a little.
Posted on Dec 29, 2008
  • 2336 Answers
SOURCE: HD ready?
Your TV will be able to pick up the OTA channels by installing an outdoor antenna. After installing the antenna you will need to do a channel scan.
It is hdtv compatible, no need for a converter box but if you have cable TV or satellite, you still need to subscribe for the HD channels.
Hope this helps.
Posted on Jan 17, 2009
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
  • 73 Answers
SOURCE: Need eyepieces for Nikon Monarch ATB 8x42 Binoculars
If its the caps that cover them Nikon in your country can order them. They take about six to eight weeks if they are not in stock. If its the actual eyepiece lens an all you would need to have purposfully removed them and in doing so destroyed the waterproofing. If its the caps contact Nikon. You can also download the instructions from their website.
Posted on Jul 31, 2009
Viore tv code for ge remote 24865
Just do a code search method, rather than seeking code list to this remote. If the remote have pr-loaded code for Viore TV, this proceeding will help you. If not, you have to buy an other remote control, which have setup codes for Viore TV in its code list.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
If you succeed, there is a way to retrieve the code that was synchronized with your TV. To get more details about it, visit this site 'Electro-help'. Type in 'electronicshelponline.blogspot' to your browsers search box, and click search. It is a blogspot site, in English language. Pull up older posts there. Have all details about codes, code search, retrieving the code etc:-
Jun 23, 2012 | GE 24965 Remote Control
I have a Husqavarna Designer II sewing Machine and the language every time I turn off the machine and then power it up again stays on another language. I have read the book many times on how to change the...
Hello Michella Linton
On the touch screen touch "English" until your language choice is indicated. The language setting remains until it is changed. Refer to manual page 21 which can be downloaded free from this link: http://manuals.husqvarnaviking.com/
Happy Stitching
Sewingirl/
Apr 18, 2017 | Sewing Machines
I ned to reset the time on my orbit 2 station hose water timer and I lost my manuel. Please help.
To reset your timer, you'll need to replace the 3 AA batteries then press the reset button on the back of the housing.
If you'd like to refer to the manual, you can find the manual at orbitonline.com. Just click on the "manual and guides" link under the "Support" heading found on the left hand side of the home page. Enter the model number of your timer "62015" and click the quick search button. Your search will provide a link to the manual in up to 5 different languages in a pdf. file format. Click on the manual of your choice. Once the manual is downloaded (this will take a second or two if you have high speed) onto your computer you can print out the manual for future reference.
Hope this helps.
May 16, 2011 | Orbit 2-Dial Hose Faucet Control Timer...
What is the reset for and do i have to reset language
The RESET button on the unit will wipe out any personal information, like routes and destinations, that you have added to your GPS unit. All of your Favorites will be erased. You would normally only use the RESET button if your unit is locked up or "frozen", and nothing you do will get the unit to function. Once the unit resets, it will behave and be setup the way it was when you first took it out of the box and turned it on.
If you need to change the language that the GPS uses you just have to go to the SETUP menu. Then chose the icon for Language. The screen will change to a box that will show the current language, with an arrow on either side. Use the arrow to scroll to the language of your choice. Once you see that language you would choose the box underneath that has the word DONE in it.
If you need further information about the language function please let me know.
Feb 15, 2011 | Nextar 43NT GPS Receiver
Explorer.EXE not booting up!
Boot your cd installation your windows 7 ultimate after restart then in menu installation your choice repair then stay if finish you cant choise about your repair if there you must choice repair start up stay after finish and restart your computer. good luck
Apr 26, 2010 | Computers & Internet
I require a French manual for the Sansa 4GB Fuzion MP3
Download the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Dec 29, 2009 | SanDisk Sansa e260 MP3 Player
Jul 08, 2009 | Nikon Monarch ATB 7344 Binocular
Foreign language need english
You have a choice:
If you know the language being displayed but don't know what the screen options are saying then type the options into the translation service at:
http://www.freetranslation.com/
If you can't work out the language then you can use the instruction manual to find out how to do a hard reset on the device. Usually involves poking the end of unfolded paperclip into the reset hole or something similar. The first thing it will normally ask you is to set the language.
HTH
Peter
Jan 23, 2009 | Garmin Nuvi 660 GPS Receiver
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
