Question about Microsoft Windows XP Professional for PC
Windows Boot up dual boot xp home and xp pro
I don't have pro on the pc ? I did set the Boot ini to 0 still no good ?
  • 47 Answers
You have to set the OS on different partitions, not on the same one.
Posted on Jan 13, 2009
Advent will not BOOT
The BOOT.INI file may be corrupt. Boot to a command prompt and rename original file c:\ren boot.ini boot.tmp. Now type edit. and insert the following script.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Save as boot.ini. Alt key gives you the menu options
You can also create the file elsewhere and copy to c:\ Remember to rename original.
Note! This is a single partition standard from factory configuration.
Oct 25, 2012 | Computers & Internet
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
My matser hd oin is aet to master. My slave is set
If you have the XP install disc just disconnect your master HD and use XP disc to format the slave drive. Exit after format, remove XP disc and reconnect Master. You now only have 1 drive with an OS.
Oct 05, 2009 | Symantec Norton Partition Magic-8.0...
Computer starts up in DOS
What operating system do you have installed? If you are using windows Then you need to repair your boot files. Start with boot.ini. you can open this using notepad editor. the info should read:[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Thats is you are using XP Home Edition operating system. If this doesn´t work then you need to run msconfig. Start menu select Run, then type msconfig.Startup selection should be normal check box. System.ini should have all check boxes checked,Same as win.ini, when you get to boot.ini tab, no boxes should be checked. I hope this helps. Start with the second method first ok.
Mar 10, 2009 | Dell Dimension 4600 PC Desktop
Dual Boot problem in Windows XP & VISTA
Don't try to edit the xp boot.ini or the vista bootloader. It only leads to other problems and headaches.
Try this first: Take note as to which drive has vista on it, put your vista installation cd in the drive and let it boot to the "installation window", then choose "repair", then "startup repair." Make sure you choose the drive that already has vista on it. Let that run and when it re-boots you should then be given a choice to boot to vista or "other windows".
There is also a (free) program called EasyBCD. Download that, read the directions and have at it.
If none of that works, you'll have to do a clean install. Install XP on one drive first, then Vista on the second drive in that order. The Vista bootloader will pick up the XP. However, XP is NOT forward compatible and will not recognize the Vista bootloader. Make sure that you don't have any flashdrives or media cards plugged in before doing the install.
Another approach would be to shrink the Vista volume, creat a new partition, then install Linux Ubuntu that partition. Linux will detect all of the OS's and create a boot menu. Unfortunately, you'll lose about 5 gigs to the Linux OS and it's swap partition, but then, you get to goof around with Linux :-)
Feb 25, 2009 | Microsoft Windows Vista Home Premium with...
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
Dec 28, 2008 | Microsoft Windows XP Professional
BOOT.INI deleted. How to re-create this file?
timeout=30
[operating systems]
Please rate this if you found this answer helpful. :)
Invalid boot.ini
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Oct 04, 2007 | Intel Motherboard
Microsoft Windows XP Professional for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
