My phone is locked to globe telecom in the Philippines
Hi visit Mobileunlocksolutions.com to unlock your mobile from Philippines globe network .Here they ask you he mobile model and the IMEI number of your mobile .Then they deliver your code to unlock your mobile.
SOURCE: 6300 restriction code
A word of advice dont publish your imei somebody can mess it up like a pie for all seasons.
Before trying anything else, contact your service provider and ask for an unlock code.
Usually, if you've been a customer of theirs for some time, they will provide you with an unlock code for free. This is, by far, the best way to get your phone unlocked.
Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 6300phone, select the model 6300, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code (MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that says "SIM is not restricted" or "Restriction off" message depending on your model.
If not, try entering another code. Message "Cannot undo restrictions" means the phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies, cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on. Keep the buttons held down till you see the word "Formatting..." on the screen. Make sure that the battery is full charged before you attempt this. This should reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked without using special equipment.
Most of the newer phones will not work with the codes generated by the free unlock programs.
You can get a free unlock code generator software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
Good Luck.
Live, Love, Laugh.
SOURCE: UNLOCK CODE NOKIA 5070 IMEI:354830010387993 COUNTRY:PHILIPPINES NETWORK:GLOBE TELECOM
You need to buy unlock code. Code you can get from me via my website www.softzonelab.com
that is only solution you can do with
SOURCE: I need a restriction code to unlock my Nokia 1680c-2 phone
i need unlucking keys for 1680 locked in globe telecom.
SOURCE: unlock code for LG KU250
for LG KU250, I got unlock from this site http://www.prounlocking.com/unlock-your-phone/rs8wp2/
It has the best unlocking solutions.
Try this site and gain solutions.
SOURCE: please help me unlock my
waiting mode lang po muna sim/ma'am,kung meron man pong openline niyan eh baka mas mahal pa po sa unit or more than half the price and charge if you avail online codes.wala pong magbibigay ng free codes sa mga bagong model sa ngayon..
please rate me....thanks po
