Question about Targus Computers & Internet
Targus PAUH217U 4-Port USB Hub drivers windows 7
I need conect this hub to my notebook vaio 64bits
worldvet
  • 859 Answers
SOURCE: Targus Travel USB 2.0 4-Port Hub with Notebook Light
I'm sorry to tell you your hub cannot be fixed. I have one just like it and have taken these things apart and repaired simple factory errors as loose wires and the such.
You should get yourself another Targus brand USB hub. They are good and quite reliable
Regards,
Worldvet.
Posted on Jun 08, 2008
Geekman
  • 32281 Answers
SOURCE: Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Posted on Nov 13, 2008
  • 1141 Answers
SOURCE: Any thoughts on 'COMPAQ USBFW 7-Port USB 2.0 /
Firewire/USB 2.0 hub works perfectly with my1999 G4 Sawtooth Mac running Panther. If you are not esthetically offended by the Compaq logo on the hub, you will be a happy camper. This hub comes with the usb 2.0 and firewire cables included. The inclusion of the cables constitutes a significant savings. Comparable hubs do not include the cables which are pretty expensive to buy.
Posted on Aug 12, 2010
  • 1141 Answers
SOURCE: USB hub problem.i have a 4-way USB powered hub
Perhaps the problem is not with the powered USB hub but rather the USB port it is plugged into, or the cable connecting them.
Plug the USB hub in using a different USB port on your system or connecting it using a different cable to see if that makes any difference.
Posted on Aug 15, 2010
  • 11 Answers
SOURCE: i plug in the 4
sometimes you have to plug a usb into these to get them to respond if this does not work try plugging it into another USB port. If this does not work than look at the wires they may have come unattached
Posted on Feb 05, 2011
Cable for Targus 4 hub usb2 model PA055u
Use any USB cord available at electronics stores that has a male on one end and a female on the other, obviously of the correct length.
Jan 23, 2013 | Targus PAUH217U 4-Port USB Hub
Targus 4-Port not working
First off hubs don't support a lot of power hungry devices so you should be able to buy an optional power adapter for the hub on targus' site.
Second if your computer doesn't have any usb 3 ports then the hub will only operate at usb 2 speeds.
Your probably overloading the hub. Buy the power adapter.
Dec 22, 2012 | Targus 4-port USB Hub Group International...
USB ports do not work with windows 7 acer
I Got off the phone with Acer Support...the lady with the heavy accent was very pleasant and informative. She told me to do System Restore and I have done so back to the 16th. Still no yellow marks in device manager everything says working properly. My flash drive still has no response but my blackberry power symbol shows up and charges but will not detect as a device in Computer. She recommended a "Full System Recovery" basically re-format. I really hope I don't have to do that I just bought this thing less than a month ago...I do a lot of computer work for others but no experience with windows 7 or vista and first time ever seeing a problem with USB.
Porsche Parts
May 27, 2012 | Targus PAUH217U Ultra-mini 4-Port USB 2.0...
I plug in the 4 port usb targus and it doesnt respond
Jan 22, 2011 | Targus 4PORT USB 20 TRAVEL HUB ACH7405US...
I bought a 4 port usb hub targus and it doesn't work with my windows 7
Right click on my computer or the icon for my computer and select manage then open device manager and see what it says in there then up top select check for hardware changes icon, this should look for and install the hub
Jan 01, 2011 | Targus PA055U 4-Port USB Hub
My Targus keeps disconnecting what is connected to it then will reconnect (seems random) anyone else having problems with disconnecting devices plugged into the hub? Model ACH7405US
This USB hub is not powered by an AC adapter. Therefore, some devices that need more power will not work well on it. You don't mention what it is you are pluggin into it, but I suspect this may be your problem. Devices like webcams pull way too much to be on a hub without AC.
Did I solve your problem? If so, please rate this. ty.
Feb 26, 2010 | Targus PAUH217U 4-Port USB Hub
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Regards,
Worldvet.
Jun 08, 2008 | Targus 4-PORT TRAVEL USB 2.0 HUB...
Computers & Internet Logo
87 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
