Question about Porter Cable 19.2V Drill/Driver
Porter cable drill 822 battery red green - Porter Cable 19.2V Drill/Driver
5 Suggested Answers
danny_murray
  • 55 Answers
SOURCE: porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Posted on Dec 05, 2008
  • 4 Answers
SOURCE: Do you know which is the positive and negative
Get a volt meter and make sure red is on v/ohm and black cable plugged into common or ground. measure the battery. if the meter is reading a negative reading then polarity is backwards. look for a positive value of 19v +/- a volt. red will be positive. if there is 3 leads I would think the temp lead would measure different. Usually common would be the negative side.
Posted on Jun 22, 2010
  • 885 Answers
SOURCE: Can I get the schematic drawing for a Porter Cable
There is a good parts breakdown for this drill on www.ereplacementparts.com. They are also a fairly good place to get replacement parts but most of the parts for this drill are discontinued.
Posted on Nov 18, 2010
eugbug
  • 479 Answers
SOURCE: Porter cable hammer drill 987
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Posted on Mar 04, 2011
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Jan 20, 2016 | Porter Drills
Porter-Cable battery charger model #8605
go to www.dewaltservicenet.com and enter the model number of your drill. It will get you to the parts breakdown and will tell you if there is a charger available from the factory. Or call 1-800-433-9258 1-800-4DEWALT. stanley black and decker owns all of them so yes that's the right place!
Jan 02, 2013 | Porter Cable 19.2V Drill Kit
I am having problems with my 18v porter cable cordless drill. I have had it for two year and have rarely used it. Only used one battery. Now I am unable to charge either of the batteries. They are lithium....
Do not try to repait the battery. There is a possibility you could fix it but don't try it. Acid is not friendly on humans body.
go out and buy new batteries for it. I would suggest you buy the type of battery it came with.
One more thing; Make sure you remove the battery and store it in a normal temperature area anytime it is not in use.
Please rate if this helped you.
Apr 17, 2011 | Porter Cable-Cable PCL180DK-2 18-Volt...
Porter cable hammer drill 987 suddenly stopped running.
Mar 04, 2011 | Porter Cable 987 19.2 Volt Grip - To - Fit...
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
Do you know which is the positive and negative prong on a 19.2 porter cable drill battery
Jun 17, 2010 | Porter Cable 19.2V Drill/Driver
Porter Cable 19.2V Drill/Driver Logo
24 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Tom Chichester
Steve P
Steve P
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
