Question about Sharp AR-207 Copier
Maintenance indicator sign in SHARP AR 5618 - Sharp AR-207 Copier
tehnik_bdg
  • 91 Answers
SOURCE: how do i clear the maint indicator on a sharp ar m 257
PRESS [#] [INTERUPT] [C] [INTERUPT] [20] [START]
Posted on Jun 09, 2009
Cogz
  • 1326 Answers
SOURCE: Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
Posted on May 09, 2008
Cogz
  • 1326 Answers
SOURCE: Reset Code
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
Posted on May 15, 2008
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 990 Answers
SOURCE: Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
Posted on May 30, 2009
My sharp AR-5618 indicates an error code F then 2 and 64 when i press the button
check you toner and drum cartridge are they third party if so get OEM
Dec 15, 2015 | Sharp Office Equipment & Supplies
How do i clear error f2 70 on sharp ar 5618
Service Manual SHARP AR 5618 5620 5623 SME honestly I did not see this code in the owners manual but it should have a number you can call to ask how to clear it. I've noticed a few people have asked this question for this specific product but haven't gotten any answers. If you do find the solution please post it for people with the problem in the future :)
Sep 27, 2015 | Sharp Office Equipment & Supplies
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
Sharp AR 5618
Well, with only the product name, all I can help you with is some information about the product. Here is a link to a product description:
Sharp's product description
and here is a link to the product manual:
User manual for Sharp AR 5618
If you have a specific problem, please post again. I hope this helps.
Sep 27, 2013 | Office Equipment & Supplies
How to reset the Maintenance indicator sign in SHARP AR 5618
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Dec 09, 2012 | Sharp AR-5320 Black and White Copier
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Aug 04, 2012 | Office Equipment & Supplies
How to reset Total counter on sharp AR-5618/5620 copier
Please give me code to increase the brightness of Sharp AR5618.
Jul 26, 2012 | Office Equipment & Supplies
Sharp ar 5618 meter reeding reset
i want to change meter reading of sharp ar5618
May 03, 2012 | Sharp Office Equipment & Supplies
Sharp AR-207 Copier Logo
280 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
