Question about IBM Aptiva E 240 (2158240) PC Desktop
Insert system diskette and press enter key to reboot i don't have system diskette
I do not have a system disk to reboot
2 Suggested Answers
SOURCE:
mikaljalil
  • 15 Answers
SOURCE: DISK BOOT FAILURE
If you reinstalled the memory correctly it should fire right back up. But try this, when press the power button, hit delete and go to set up, under PC management find the Boot Order String, select the Floppy as the first device if you have one, the Hard drive as the second Device and the CD/DVD as the last device. Should go straight to the hard drive as the primary boot device. Hope this helps.
Posted on Jul 05, 2008
I have a laptop that is a Compaq Presario and upon start up it says the following a kernel file is missing from the disk Insert a system diskette and restart the system how do I fix this
Which kernel file are you missing?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following commands and press enter after each one:
sfc /scannow
chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 04, 2012 | Compaq Computers & Internet
I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
Related errors
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you load the last known good configuration.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
http://www.computerhope.com/issues/ch000646.htm
Mar 02, 2012 | Gateway GT5026E PC Desktop
Ntldr is missing at startup
To fix your problem please follow the below steps.
1. Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further.
2. Restart your computer.
3. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer.
4. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear.
5. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
Thanks for contacting Fixya. Have a good day.
Aug 10, 2011 | Dell Dimension 4600 PC Desktop
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
Unable to boot and hard disk prob
Dear Amit Sinha
First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
If not then it seems that your windows boot file got corrupted. all you have to do is try using your notebooks recovery CD if you dont have a recovery CD then you have to use the windows installer CD
1 Insert the Windows XP bootable CD into the computer.
2 When prompted to press any key to boot from the CD, press any key.
3 Once in the Windows XP setup menu press the "R" key to repair Windows.
4 Log into your Windows installation by pressing the "1" key and pressing enter.
5 You will then be prompted for your administrator password, enter that password.
6 Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
7 Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Else you have to format your computer and reinstall windows again
Thanks
Gagan Gupta
Is that helpful
Mar 17, 2011 | Excel MERIDIAN DATASHARE X2 CD/DVD SERVER...
I am getting a disk 1/0 error and am not confident at all with computers. How can I fix this so my son can use the computer? My PC is about 6 years old and I only ever used it 9-10 times
A..Access the BIOS setup by pressing the key designated for your BIOS at Startup? It can be Del/F1/F2 or whatever and will be shown on Boot Screen before Windows is loaded.
B. Do you have a Win98 Boot Diskette proven to work well in a PC?
If so:
1.With the Win98 Boot Diskette in the Floppy Drive, Restart the PC.
2. Press the BIOS key [Eg:Del] enter BIOS setup
Check for correct YYYY/MM/DD and Time for your Time Zone and proceed to take a good look at the entries of your IDE devices and Floppy Drive with special attention to your Hard Drive(s) in IDE section. If they are all properly identified and normal, you can EXIT the BIOS. [ It does not mattere "Save changes" or "don't save changes" as you have not made any changes.]
3. Wait for Boot Disk to be accessed and Windows Startup Menu to appear with the Options:
1.Start Computer with CD-ROM support.
2.Start Computer without CD-ROM support
3. Help File
4. Select the option,1.Start Computer with CD-ROM support. and ENTER
5. Watch the screen for CD-ROM driver installed successfully" and "Diagnostic Tools " installed and CD-ROM drive letter designation and finally appearance of A:\Prompt
6. At, A:\ Prompt type FDISK and press ENTER.
7. Accespt Y at the bottom of "Large Disk Support" message.
8. At FDISK menu select #4. Display...."
9. Check if the HDD is shown as C: A FAT32 and size.
I am suspecting a problem somewhere here; so if you don't have an Active C: drive press ESC >ESC and remove boot Disk CTRL +ALT+ DELETE to reboot and post back
If you have an Active C: drive, press ESC >ESC to A:\Prompt and type in C: and then at C:\> prompt, type DIR and [ENTER] look for Windows Directories. Here is another Problem area. If you cannot Find any Dir or get an Error, make sure your typing and spacing are OK [ No space after Drive letter for the Command] and if so, ALT+CTRL+DEL or Power Off.
If the problem is same do next .
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
Or
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and/or NTDETECT.COM file.
Misconfiguration with the boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable.
Solutions:
CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows 2000 users
If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers.
Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516.
Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Windows XP users
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
At the A:\> prompt type:
sys c:
After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Hope this helps ,
Jan 26, 2011 | Gigabyte GA-8SRX Motherboard
Hello,pls I am having problem with my laptop IBM R30. Whenever I turn it on,It displays NTLDR file missing.MY mail is [email protected]
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers. Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516. Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive. copy ntldr c: copy ntdetect.com c: After the above two files have been copied, remove the floppy diskette and reboot the computer. Windows XP users Insert the Windows XP bootable CD into the computer. When prompted to press any key to boot from the CD, press any key. Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer. copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jun 05, 2009 | IBM Computers & Internet
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
NTLDR is missing
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Windows 2000 users
Windows XP users
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
IBM Aptiva E 240 (2158240) PC Desktop Logo
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
