Question about GE HO98010 Computer Speakers
My speakers sound like the sound is playing underwater
I've had my speakers for less than a year and recently they have been acting temperamental, sound goes in and out, one speaker sounds much lower than the other. And now they both sound like they are playing underwater. What's happening? How can i fix it?
  • laurielove Jan 25, 2009
    the underwater sound on my computer is across Skype, itunes, you tube and radio. Would new speakers help or is the problem in the computer?
    from laurielove
  • rayza214 Apr 08, 2009
    same deal... tried the same speakers on another computer and they work fine.... must be a sound card issue or maaybe drivers
It sounds like you have some wireing problems. You might check that out and also try adjusting the bass and treable.
Posted on Jan 13, 2009
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
I am having problems with my brand new JVC car stereo. It stops playing after a few minuets. I installed it properly. All connections are soldered and insulated with heat shrink tubing. If I shut it...
it sounds like you may have a bad speaker. if you can, check the resistance of each speaker. it should be about 4 ohms. if one is less than 3 ohms, that is probably what is causing the problem.
Jan 27, 2011 | Car Audio & Video
Sounds like underwater
Sounds like youve got the Realtek soundcard software. You have got the sound effects which are built into the software turned on. You should see the Realtek sound manager icon in the bottom right taskbar just right click on that and go through all the options making sure no effects are enabled. Also right click the speaker icon then recording devices and go through all the settings there as sometimes there is also a box needed to check to disable sound effects even though it says none in the Realtek manager. Cheers from Scott and please dont forget to vote
Jul 15, 2010 | Compaq Audio card Sound Card
Radio Interferance on my logitech computer speakers
You may be now living too close to a radio station. Sometimes when this is the situation, anything electronic gear plugged into a wall socket can act like an antenna, thus receiving signals from local radio stations.
Mar 10, 2010 | Logitech X-530 Computer Speakers
Sounds like my computer underwater
Try to update the Itunes and Mac OS X.this can solv the issue
Mar 09, 2010 | Apple MacBook Pro Notebook
Hello, I've just recently bought a Peugeot 206 (2001). Unfortunately, the air conditioning is acting up. It is very temperamental and can be on one minute and off the next. This is extremely annoying, as...
IT SOUNDS LIKE THE THERMOSTAT IS FAULTY OR COULD BE THE FRONT FAN IS NOT WORKING IF THE FAN DOES NOT WORK THE SYSTEM OVER HEATS AND THE HIGH PRESURE SWITCH WILL CUT OUT THE SYSTEM
Aug 31, 2009 | Peugeot Liberte Cars & Trucks
No sound when playing dvd from speaker system
I recommend going to the sound icon on bottom of main screen, right click, go to the properties and settings. Make sure the system is set for the same amount of speakers as you have. You can also use the test button and see if the settings are correct.
Make sure you are using the correct audio decoder or ac3 filter
Aug 17, 2009 | Audio Players & Recorders
It's probably just a playback setting but, take it back anyway. Let them see if they can make it right. If not, the repair's at their cost.
May 02, 2009 | Polk Audio AMR50 Computer Speakers
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Toshiba 42H 94 speker sounds like its underwater
There may be a fault with the speaker driver, or the output stage circuits, or the audio decoding circuits.
Without proper troubleshooting, it is impossible to pin-point the exact fault.
Jerry G.
May 16, 2008 | Toshiba 42H81 42" Rear Projection...
GE HO98010 Computer Speakers Logo
2,449 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
