Question about Rolex Datejust Watches
Watch wound too tight
Stopped working
  • 6 Answers
SOURCE: The watch stopped working
Did you find a solution Ande?
Posted on Nov 05, 2008
  • 2501 Answers
SOURCE: juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Posted on Feb 02, 2010
Testimonial: "I'll try that, thanks for the info!"
escapement
  • 2334 Answers
SOURCE: Have old Mickey Mouse self winding watch. Bought
I will explain from the last question asked. To get it going you have to visit your nearest watch repair shop and ask for estimate. Shop owner told you things he/she do not understand at all - self winding watches CAN NOT BE OVERWOUND, so, there is the question: are you sure this watch is self winding? I've experience of 26 years of watchmaking and have never came across Mickey Mouse watches having self winding movements. As far as I know, all MM watches are battery driven, but in case if you really have the mechanical one - you are lucky. That means there were past times when those watches were fitted with mechanical movements and now they are rarities. Even if your watch is not self winding, but is mechanical (not battery driven), visit your nearest watch repair shop and ask to check this watch out. In case if it is mechanical - pay the money and get it fixed (you will be a winner anyway). If it is battery driven - put it on your shelf where your's mother in law picture is and treat it accordingly. Rate me , plz.
Posted on Feb 19, 2010
  • 8 Answers
SOURCE: Watch will not wind. Wound
The best solution is to lightly tap on the watch, this will keep it running until the spring is unwound enough to run on it's own.
Posted on Jan 08, 2011
  • 6771 Answers
SOURCE: Watch is wound too tight
This a job for a jeweler, he has the equipment to work with the miniature parts that require a steady hand and lots of skill.
Posted on Jan 14, 2011
I have wound muy omega speedmaster automatic to tightly at the bezel and it has stopped working. Can you tell me if there is something inside that can be released tostart it again?
There's a misconception that mechanical watches can be "overwound." Mainsprings in old watches can indeed set in place and freeze up if they are wound tightly and not permitted to unwind, but the steel used in modern mainsprings used in the past 50 years or so is an alloy that's much less likely to bind up compared to 19th century pocket watches. In addition, the winding mechanism in an automatic (aka, self-winding) watch is designed to slip once the spring has been fully wound so that the rotor and winding parts aren't damaged by suddenly binding up. In a manual wind watch, once the mainspring is fully wound, it's simply not possible to wind the watch further unless the mainspring snaps or comes loose from its anchoring--in which case, you'd be able to wind the watch forever without ever storing power in the mainspring to drive the movement. While it is possible for a watchmaker to open your watch and release tension on the mainspring, it's overwhelmingly likely that something entirely different is keeping your watch from ticking and keeping time.
Mechanical watches generally stop running for two reasons: (1) lack of power to the movement; or (2) something in the movement that is preventing the movement from running. If your mainspring is fully wound, you have power to drive the movement. It's time to think about what could be causing #2.
Problems in the movement are usually caused by dust or dirt that preventing a delicate movement part from working properly (e.g., dirt at the pivots can freeze up a gear, stopping a movement). However, it's also possible to have a mechanical failure, such as a bent tooth on a gear in the train. A further possibility is so-called "overbanking," which some believe is the origin of the myth of overwinding. A mechanical watch's balance assembly drives a tiny little forked lever back and forth to control the escapement and the rate at which the watch keeps time. If the watch receives a physical shock or if the parts are worn, it's possible for this tiny lever to get bumped out of its tiny pivot and jammed in place. When that happens, the watch will stop, even though a superficial check will seem to indicate that the balance is still moving freely. At the same time, because the watch isn't ticking, the mainspring isn't unwinding, and so the watch cannot be wound further.
In my experience, watches usually stop running due to dirt at the pivots or on one or more gear teeth. I generally see overbanking in older watches or mechanical watches that have been less precisely made and not routinely cleaned over their working lives--though I have seen it also occur in a few newer watches that were dropped. Better designed watches--and I would include Omega in this category--have escapement levers with built-in guards to make it more difficult for them to overbank.
As for how dirt gets into a watch that's supposed to be water-resistant and generally sealed against exactly that problem--well, as odd as it sounds, watches "breathe," and this process draws in dust and dirt over time. Worn against the body, a watch warms up and expands the air inside it, pushing some of it out of the case; upon cooling, some air is drawn back into the case. This process is obviously reduced in watches designed with a significant degree of water resistance (aka 50 meters or more), but the process is accelerated when you pull the stem out to set the time or even wind the watch via the stem--there's some degree of air gap between the stem and the stem tube, or else it wouldn't be possible to turn the stem. This microscopic dust--in minute quantities--mixes with the lubricating oils inside a mechanical watch and increase the friction in some of the key pivots. Over time, the combination of naturally solidifying oils that are thickening and a minute amount of dust can turn lubricating oil into glue. The watch cleaning process flushes the old oil and accumulated dirt from the pivot bushings so that fresh, uncontaminated oil can be used to re-lubricate these key gear axles.
Bottom line: if your mechanical watch has stopped working, it's much more likely that something is interrupting the intricate gears in the watch movement rather than a problem with the mainspring. A competent watchmaker or watch repair technician should be able to identify the problem relatively quickly and give you a definitive answer as to the true cause of--and cost to fix--your watch.
Jun 11, 2011 | Watches
How do i fix a watch thats wound too tight
Well, you begin with the correct premise. Your watch isn't wound too tight. It just isn't running so you made the 'assumption' it was because it is fully wound. Your actual problem is the watch isn't running and therefore the spring is not running down. It may be not running for many reasons. Suggest you take it to a watchmaker and he/she may be able to help you.
Mar 14, 2011 | Watches
Watch will not wind. Wound too tight. How do you fix a watch that is wound too tight?
Jan 08, 2011 | Watches
I stop using mi nixon watch " THE 51-30" for a month and now it doesnt work.
Your watch is an automatic type which means that it is a mechanical self winding watch powered by a spring. It is wound up by a weight that moves when you are walking about and this watch must be worn to keep it operating.
If not worn, these watches will stop in 2 -3 days because the spring has run down.
Some automatic watches can be wound using the crown wheel (winder) but if yours cannot be wound in this way, then swing it from side to side gently for a few minutes and the watch will wind up.
These watches thrive on being used.
Oct 27, 2010 | Nixon 51 30 Watch
I don't know how to wind the watch....can you help?
WIND AT THE SAME TIME EVERY DAY. This is extremely important. In order to ensure that your watch keeps good time it must be wound at the same time every day. Most people like to do this at night before bed.
WIND ALL THE WAY. The watch must be wound all the way, or it will slowly lose the proper time and require constant resetting. Also, if not wound all the way, the watch may stop keeping time earlier than expected.
WIND IN THE RIGHT DIRECTION. Most European watches wind clockwise when the face of the watch is pointing towards you. Determine which way your watch winds, and stick to that direction. To figure this out, try to turn it both ways. The wrong way will either be extremely loose, or extremely tight.
Tips & Warnings
Keeping your watch clean and free of dust and dirt will also add to its longevity.
Contact the watch's manufacturer for any special and/or specific care methods.
Don't under or over wind you watch. When you start to feel resistance, STOP.
Aug 17, 2010 | Watches
Tag Heuer Tiger Wood Golf WAE1111.FT6004 Watch stops when not worn. Is there a problem
An automatic watch needs to be worn, wound daily or placed on a watch winder to keep it going. It is not like a quartz watch that has a battery and can keep going when not worn. A modern automatic watch will run for about 36 - 48 hours on a full wind.
A quartz watch that stops like you describe is in need of a cleaning by a professional watchmaker. When this stopping occurs it is an indication the oils have dried out and the warmth from your body heats them so they are semi liquid again and the watch runs. but when the watch cools again the oils harden and the watch stops.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 21, 2010 | Tag Heuer Tiger Wood Golf WAE1111 Watch
Pocket watch seems overwound
INFO:
If you wound the watch and it ran you would not say you over-wound it.
The only way it is over-wound is if you wound it so Hard you broke the spring or broke off the stem.
The fact is your watch has Stopped running.
RECOMENDATION:
Seek professional help.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 09, 2010 | Watches
Juts got the watch, wound it, worked then stoped, wound dead
Feb 02, 2010 | Rolex Daytona 116520 Wrist Watch
How do you know when you've wound a 1926 Waltham watch enough?
If you wind it gently, (do not apply a great force), it will slip in you fingers when it is fully wound.
If it stops frequently, it could be that it needs cleaning. As it is a very old watch, specialist advice might be worth paying for.
Good luck
Dec 28, 2009 | Watches
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
Apr 08, 2007 | Prague 49011-M1
Watches Logo
111 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
