Question about Ariens 34 In. Zoom Series Riding Mower
Snowblower starts for 3 sec. then shuts off
If you keep priming it will run longer
  • jonelson628 Jan 13, 2009
    thanks, it was dirt in the bolt in the bowl
    Scholar:
  • 76 Answers
First check your fuel, if it smells stale or smells like paint thinner, your carburetor may need to be cleaned. If the fuel smells ok then you'll need to take the bowl off the carburetor be careful of the bowl gasket, it will probably stay on but when you put the bowl back on be sure it seats evenly around. With the bowl off check to see if there is any water, debris or anything else that don't look like fuel. If your engine is a Tecumseh then you should also check the bowl bolt. Assuming it is a Tecumseh the bolt will be one of 3 different types but what you need to look for is the holes on the bolt, there will be 2 down by the head of the bolt and sometimes 1 real small one at the top of the threads (use a twist tie from a loaf of bread with the paper cleaned off to clean the little hole). If the little hole gets clogged the engine won't run. If everything looks good then put the bowl back on and try it. If there is stuff in the bottom of the bowl the you might want to take the carb . off and clean it and to bee on the safe side while it's off put a new carb. kit in (carb kits usually run about $10 to $15 dollars). Any questions on taking the carb. off, cleaning or rebuilding feel free to ask.
Posted on Jan 13, 2009
  • Mark Tripp
    Mark Tripp Jan 14, 2009
    Your very welcome, anytime
  • Mark Tripp
I have a hitachi cs40 and whe I prime it 10 times it starts up and runs until the prime is gone the shutsdown.
rebuild the carby as the diaphragm is not functional and pumping the fuel up
Feb 05, 2017 | Cars & Trucks
12ht wont prime
filling the filters before installing will make priming go more quickly.
once the pump is primed crack open the fuse line at the injector while cranking until you have fuel pulsing out, close it then move on to the next injector.
keep doing this until the engine runs smoothly.
it may start running before all the injectors have been purged so keep clear of all moving parts and a fire extinguisher handy would be a good idea.
Apr 14, 2013 | 1989 Toyota Land Cruiser
Lawnmower has been in storage for 6 months. Has new good gas, and gas is flowing to carb. However, engine will not start without priming carb with gas, then runs until primed gas is exhausted. ...
this is from a post i just did for anothe engine but i think it applies to you also.
get a product called START. this stuff is amazing it has solved all my engine problems including a couple like yours. any wal mart should have it. add to your gas and the longer it runs the better it runs. i am telling you it is worth the 6 bucks. i had a 4wheeler that never ran right, always had to half choke it. even though i cleaned the carb twice. added this stuff and by the time that tank was gone it was running like new. if that doesnt take care of your problem then it needs to go to the shop Now your situation i know is dirt or varnish in the carb i have had this problem also. and start worked for me on that also. mix it in the gas and keep it running even if you have to keep priming it
Nov 12, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
Chipper/ Shredder runs for while on the amount you primed the eng
Check to be sure there isn't a small hole or crack in the priming bulb. If there is it allows air to enter fuel line, loosing the prime. Most have a collar that unscrews to remove it.
Jul 18, 2010 | Troy Bilt 24b - 060f766 5hp Chipper...
Wont continue to run after prime and start
often the last ounce of gas in the tank has some crud in it. Get a can of carbeurator cleaner spray. Remove the air filter and squirt three short bursts of the cleaner spray into the air port and then start it. Keep giving it short bursts of carb. cleaner until it runs smoothly again.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
14" Ryobi petrol chainsaw will only run for 10 seconds
You are on the right track. Keep priming which indicates the fuel mixture is too lean to run. In other words the fuel line is partially clogged up. A drop of water on the gas tank would cause this problem. The fuel is fed on the suction basis. So clean up the fuel tank, (disassembly the carburator) reservoir, needle, float, offrice and fuel filter. A can of carburator cleaner (spray one) is a big help.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Mower will not stay running unless primer button continuouly pushed. Gas seems to not be independently flowing, requires manual priming to stay running. As soon as primer gas used, will stop running.
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
Apr 12, 2009 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
248 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
